Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-29-2012, 07:55 PM   #1
Kale
CF Senior Member
Kale's Avatar
Default Help! My positive battery cable won't clamp down.
04.
This cable has been off THREE TIMES and the nut is already stuck. I can't get it to clamp onto the battery.
Is there a way I can fix this? I don['t have the time or energy to replace it. And the cables are too short to put an aftermarket block on.
Kale is offline   Reply With Quote
Old 11-30-2012, 02:53 AM   #2
Kale
CF Senior Member
Kale's Avatar
So, I cut it all out. My tsunami positive battery terminal won't fit all the way down on the battery. So it's sitting up a quarter inch off the top of the battery. It's tight, though. Will this be a problem?
Old 11-30-2012, 04:32 AM   #3
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
The clamp nut on the terminal is a special beveled nut. If someone lost the OEM nut and replaced it with a standard nut,, it will not clamp. compare the nut on the one that will clamp down and the one that wont.
BC
Bill Curlee is offline   Reply With Quote
Old 11-30-2012, 07:36 AM   #4
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13
Quicksilver Vert 01's Avatar
In my opinion, you made a big mistake by cutting off the OEM terminal end. Be sure to seal any exposed bare wire with RTV sealant, or corrosion will quickly enter the connection.
Replacement clamp bolts and nuts for battery terminal ends are available at most auto parts stores.
Quicksilver Vert 01 is offline   Reply With Quote
Old 11-30-2012, 08:26 AM   #5
CactusCat
CF Senior Member
Oldtimer
CactusCat's Avatar
"I don't have the time or energy to replace it." Not good. Gotta take care of your car if you want it to perform/behave properly. Battery cables aren't expensive items. I'd think you need to take time to do it. Heaven knows that as much as I've spent to obtain my all time favorite car, I'm going to do what it takes to keep it working correctly. A little time isn't much of an investement. We're here to help....
CactusCat is offline   Reply With Quote
Old 11-30-2012, 10:08 AM   #6
Kale
CF Senior Member
Kale's Avatar
Click the image to open in full size.
This is how my positive terminal replacement fits. This is as low as it goes because the post flares out.
Is this a problem?
Old 11-30-2012, 10:28 AM   #7
K-Spaz
CF Senior Member
K-Spaz's Avatar
That's plenty, but it does appear you have it on upside down. There's a taper to it, doesn't look like you've got it right. I could be mistaken.
And go to the store and get the felt washers that stop corrosion. Can't live without them on top mount terminals.
K-Spaz is online now   Reply With Quote
Old 11-30-2012, 10:59 AM   #8
Kale
CF Senior Member
Kale's Avatar
Thanks. The terminal is the same both directions in any case.
Old 11-30-2012, 11:23 AM   #9
K-Spaz
CF Senior Member
K-Spaz's Avatar
Quote:
But the post is not.
It's tapered.
I think you have to look closer. Try sticking it on 180 out, if it won't go on proper, then you have it right. If it falls on, well, then it was wrong.
You also might have stretched or bent the terminal, cause it should not be straight. It would be if you crushed it around the small end.
Old 11-30-2012, 11:26 AM   #10
Kale
CF Senior Member
Kale's Avatar
Thanks.
Terminal is brand new aftermarket (thick nickel-plated metal)
Tried rotating it all around and it only goes on that far. I guess I'm in good shape then.
If I hadn't accidentally shattered my aftermarket power block behind hte battery I'd be good to go.. and could go work on my broken DD car lol.
Reload this Page Help! My positive battery cable won't clamp down.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
