couple of stock suspension upgrade questions
Old 12-02-2012, 05:25 PM
andy9743
andy9743's Avatar
Default couple of stock suspension upgrade questions
1999 frc over 100k everything is stock suspension wise. finally had a chance today to put it up in the air and take a look at things. sways are stock with the plastic end links, stock shocks. planning to replace the end links with metal and i found some bilsteins for a good price in the for sales last week and jumped on them. anything else to order while im at it? the bushings for the sways looked so so...these are just rubber, replace as well? also front drivers tire has movement when you grab it and move side to side. solid top to bottom side to side has considerable play. all the rest of the tires are good left to right and top to bottom. tie rod? ball joint? ran out of time to dig into it any further.
thanks guys!
Old 12-03-2012, 12:34 AM
superjet701k
superjet701k's Avatar
thanks guys!
. I have 2004 z51 front sway bar and a 1 inch rear sway bar 125 bucks plus shipping . Pm me for more info.
Old 12-03-2012, 01:43 PM
tomlink
tomlink's Avatar
I added Bilstein Sport shocks to my C5 last year. It felt better than the stock shocks but I wasn't really impressed. Then I purchased a set of C6 Z51 sway bars and Pfadt poly bushings from partstaxi.com for $200. It really woke up the suspension, I guess I must have had some slop in the sway bushings as the car now really feels sure-footed (handles way better than when new), damped, and still has a great ride. Best $200 upgrade you can do for your C5. BTW, I have the metal end-links.
Old 12-03-2012, 02:56 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I would definitely replace the shocks, sway bar end links and bushings. The A Arm bushings should be OK if the car has seen street only duty. You have a problem requiring immediate attention on the drivers front. It could be a bad ball joint, tie rod end or based on the symptoms, probably the hub. Thoroughly check out all joints, etc. and replace as necessary. Then enjoy the new ride !
Old 12-04-2012, 09:43 AM
andy9743
andy9743's Avatar
Thanks guys I'll look to upgrade the sways with some poly mounts.
Old 12-04-2012, 11:34 AM
andy9743
andy9743's Avatar
Superjet you have a pm!
Old 12-04-2012, 04:55 PM
jim2527
jim2527's Avatar
ZO6 sway bars and links and shocks w/ base springs. That's the setup I had on my car.
To couple of stock suspension upgrade questions
Quick Reply: couple of stock suspension upgrade questions
