Car turns over but will not start
Car hasn't been started in about 2 weeks but was running like a champ the last time it was started.
I go to start it today and it starts for about 2 seconds and then dies. I then go to crank it over again and all it will do is turn over unless I start pumping the gas if I do this the car will start and will stay running as long as Im pumping the gas but it dies the second I let my foot of the gas.
Also it smells very rich and sounds like something is off in the sound to the exhaust almost like a miss but I can't be sure.
No codes at all
No codes at all
Yea I pulled them from the DIC.
Picked up fuel pressure checker. Will see what that says in a bit
What's everyone's thoughts on bad TPS?
It's odd that it starts if I pump gas and stays running aslong as I'm giving it gas but dies the second I let off. If I don't pump gas it won't start
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Did you try to pull the codes or are you expecting codes to just pop up in the DIC???
OR
http://www.c5forum.com/ayc/dtcdic.php
OR
Codes!! Codes!! Codes!!
I've checked again there are NO codes except for wheel sensors that aren't there anymore.
I got a fuel pressure checker and hooked it up while I turned the key to on pressure went to 55psi. When I started the car while pumping the gas it would go up to 60 but go to 45 and bounce back and forth very fast. Should the psi be steady and not bounce?
Other than this I dont know where next to check. Makes no sense it was just running fine 2 weeks ago the last time I took it out
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How did you check the DTCs?? Using the DIC?
Do you have a security light on in the IPC?
BC
BC
And what is IPC? I've had the security issue before and it wouldnt start at all. This problem has something to do with fueling or spark Im guessing. Because it will run if I pump gas pedal and keep some gas into it, if not it dies
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IPC = Instrument Panel Console
If,,,,,,,,, you have no spark or fuel injection control, you would throw a P-0200 DTCs Pumping the accelerator doesn't add fuel like in the old days but,, it tells me that your getting too much air or too little fuel.
Check your fuel flow. If you remove the Schroeder from the fuel rail and attach a line to the end.. Allow the fuel to flow in a container and make sure that you have the VOLUME necessary to maintain engine operation. Sounds like its lacking.
BC
BC
Just pulled pass side first 3 spark plugs and they are black very black with a tad bit of residue on electrode and around ring. They are also wet and wreak of fuel
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Drop in some new plugs and see what happens.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
2000 Torch Red Hatchback
B&B Bullet Catback, Stage 2.5 PRC 5.3 heads 61cc
B&B Shorty headers, 25% UD pulley
Bassani X pipe hi flo cats, Vararam intake
Dyno tune 388/386
Dyno tune 388/386
Changed plugs and car starts without pumping gas but still doesn't idle right and it wants to die. I tap on gas and left off and car will die.
I already know for sure tuner didn't turn off any dtcs
But we know its running better with new plugs but s having an issue. What should I check next?
And again car ran perfect and idle just fine last time it was started two weeks ago.
Couldn't be a broken valve spring?
Sounds like you're still running very rich. Any signs of gas on your new plugs? Do they smell like fuel?
Yes it could be a valve spring...
Ok pulled some codes
C2120
U1300
U1064
U1096
U1016
B2860
B2282
B2284
U1255
Checked pass side valve springs and from what I can tell none are broke but they are dual valve springs so I cant be certain that the inner spring isnt broke any easy way to tell?
Started it up again and it idles fine until I rev it then it wants to die but just sputters around 500pm for a few seconds and then dies.
Does this sound like it could be a broken valve spring still? it revs up great no sounds or signs of it having an issue reving but when the RPMs come back down it struggles to stay running
C2120
U1300
U1064
U1096
U1016
B2860
B2282
B2284
U1255
Any reason it would be running just fine then all of a sudden rich while its only been sitting in my garage.
And like I asked in previous post if theres an easy way to find out of the inner spring on a dual spring is broke please do tell.
Yea I've known about that problem. I'm getting to that but that has nothing to do with the issue I'm having now.
If new plugs made it run better but still dies and idles alil odd what could possible issue be
So you're that confident that this is the problem that you can't think of anything else to check?
