Seperating the T-56 from the transaxle???
Old 09-25-2012, 07:09 PM
wetskier2000
wetskier2000's Avatar
Default Seperating the T-56 from the transaxle???
I am trying to remove the T-56 trans from the rear transaxle. I found 2 14MM bolts at the top and 2 15MM nuts, 1 on each side. I applied a little bit of prying but it's not moving and I suspect there is something else I need to disconnect. Ideas???
thanks!!
Rick
Old 09-25-2012, 07:21 PM
zeevette
zeevette's Avatar
Did you loosen the bolt that's under your shifter, controlling the linkage?
Scrap that; I meant the connection between trans and TT.
I just installed a new diff., and there's more than 4 bolts between the two junctions you mention.
Old 09-25-2012, 07:48 PM
wetskier2000
The torque tube and shifter are no longer attached to the trans. I just have the trans and transaxle assembly. I'll look for more than 4 bolts. Might be worth noting that I am removing what looks like about a 6 inch adapter from the rear diff, not the "adapter" from the tranny.
Old 09-25-2012, 08:31 PM
John B
Pro Mechanic
John B's Avatar
There is a stud with a 15mm nut on the bottom up in there. I take it off right after cradle removal because my trans jack would now be in the way. Those top bolts should be 13mm if original bolts. There shouldn't be a 14mm on the entire car.
Old 09-25-2012, 08:44 PM
lucky131969
lucky131969's Avatar
thanks!!
Rick
So to be clear, you are trying to separate the differential from the transmission, correct? The "transaxle" is the whole assembly. And yes, you missed a fastener.......STOP PRYING.
Old 09-26-2012, 07:28 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
the two bolts up top are 13's; 2 bolts, 3 nuts; put the pry bar down!!
Old 09-26-2012, 07:57 PM
wetskier2000
Fortunately, I've been around cars for a few years and generally know that if it doesn't move with just a little force I'm missing something... Just as several of you mentioned tucked up underneath was nut number 5! A little force to seperate the trans from the rear diff and apart it came!!
Thanks for all the help!
BTW: The rear axle assembly and front suspension is going to a 1969 corvette ragtop project that a buddy is doing on a custom made frame...
Old 09-26-2012, 08:09 PM
Supercharged111
Supercharged111's Avatar
Can the differential be removed from the trans leaving the trans in the car? Could the suspension cross member be left installed? I've got a small leak between the trans and diff and would like to get it sealed up. I ASSume it's just an o ring in there.
Old 09-26-2012, 10:51 PM
lionelhutz
lionelhutz's Avatar
Yes the diff can come out by itself and no the suspension can't be left installed.
Old 09-26-2012, 11:09 PM
dblerman
dblerman's Avatar
Challenge accepted!
Cut a hole in the rear storage compartment and remove differential through the top!
Old 09-27-2012, 09:52 AM
lionelhutz
lionelhutz's Avatar
Originally Posted by dblerman
Challenge accepted!
LOL, just cut the bonds and remove the rear body from the frame. You won't have to patch the hole.
Old 09-27-2012, 09:55 AM
bumble-z
bumble-z's Avatar
Challenge accepted!
So that's how they do it in Hopatcong, NJ.
Old 09-27-2012, 03:02 PM
DIXZ
DIXZ's Avatar
Challenge accepted!
Please post pictures when you do this! You may start a whole new trend.
To Seperating the T-56 from the transaxle???
Quick Reply: Seperating the T-56 from the transaxle???
