C 5 headlight door problems
Old 09-08-2012, 12:19 PM
kmt
kmt's Avatar
Default C 5 headlight door problems
last 6 times headlights were turned on, the left side did not come up.
I turned off and on switch and it would pop up. I looked at it this am
after reading threads and same thing right side up and left side down.
except that after the right side came down a loud clicking (gear skip?)
sound came from the right side. Now neither headlights come up and I hear and feel a click on the (actuator?) **** on both motors like it's trying to engage. Thanks - all responses appreciated.
Old 09-08-2012, 01:26 PM
jcgunn
jcgunn's Avatar
Sounds like you need to do the brass gear fix. Get a set from Rodney, it will only take a couple of hours to do both (plus overnight glue cure time). $86 for both, well worth it.
Old 09-08-2012, 05:41 PM
Dave68
Dave68's Avatar
Yes, definitely do both sides. Patches came up with a good, picture-filled procedure. I did mine, last year. Brass/bronze gears should last much longer than the original gears.
Old 09-08-2012, 09:26 PM
gotz06?
gotz06?'s Avatar
Old 09-09-2012, 01:37 PM
Randyman2002
Randyman2002's Avatar
This should help you...
http://forums.corvetteforum.com/c5-g...orialized.html
Old 09-10-2012, 12:34 PM
maxx2200
maxx2200's Avatar
Originally Posted by gotz06?
Very easy to do, fast shipping, good instructions and good quality parts. Rodney is the man.
To C 5 headlight door problems
Quick Reply: C 5 headlight door problems
