Turn signals dont work
Old 08-13-2012, 01:07 PM
hunter83
hunter83's Avatar
Default Turn signals dont work
Blinkers stop working after car gets warm. I was told the multifunction switch (blinker/headlight switch) was probably bad so I bought a brand new one from dealer and had them install it and blinkers still dont work. Anyone had this issue? Know of a solution? The headlights do work.
Old 08-13-2012, 01:09 PM
hunter83
hunter83's Avatar
Its an 01 Z with 110 k mi. & H/C/I fyi.
And they work when I first start car then stop working after 5 minutes or so.
Old 08-13-2012, 01:15 PM
lucky131969
lucky131969's Avatar
Have you checked for 12 volts and ground at the connectors with a meter?
Old 08-13-2012, 01:32 PM
65GGvert
65GGvert's Avatar
Received 3,235 Likes on 2,311 Posts
More likely the hazard switch than the stalk. Push the hazard switch off and on a few times and see if the blinkers work at all. If that's the problem, there's a recent post of how to change it without disassembling the dash. It's titled something like "18 minute flasher fix" or similar.
Old 08-15-2012, 03:19 PM
hunter83
hunter83's Avatar
[QUOTE=lucky131969;1581558549]Have you checked for 12 volts and ground at the connectors with a meter?[/QUOTE
Not sure I understand this. You mean battery connections? And I dont have a meter. Assume I get one at an auto parts store?
Old 08-15-2012, 03:21 PM
hunter83
hunter83's Avatar
Il try the hazard switch when I get home. Havent touched that switch in a while.
Old 08-15-2012, 06:26 PM
99 vett babycar
99 vett babycar's Avatar
one of our supporting vendors has a bypass harness that costs about 1/3 the price of the flasher. its an easy install. I'm sure someone here knows who has it.
Old 08-15-2012, 09:18 PM
LawdoG247
LawdoG247's Avatar
Guaranteed its the flasher/hazard switch. Mine is doing the same exact thing and I will be bypassing it this weekend when I get some free time, using a guide that's floating around here somewhere. Google "c5 flasher bypass" and see what comes up. A very common problem on these cars, good luck!
Old 08-15-2012, 09:35 PM
kernelPanicked
kernelPanicked's Avatar
Never tried the bypass but I went the GM route and got the part from my stealer. You could give GMPartsWarehouse a call. Anyway this guy has great instructions, this worked for me with some determination:
http://www.pc-surgeon.net/images/cfo...h%20Repair.pdf
Old 08-16-2012, 05:42 AM
SS2001SS
SS2001SS's Avatar
Hazard switch. Mine is doing the same thing. $18 from Rock Auto
Old 08-16-2012, 07:08 AM
Oleman
Oleman's Avatar
Just ordered one for my 01 Z last night. Been doing this for a while as well.
Old 08-20-2012, 10:15 AM
hunter83
hunter83's Avatar
It does appear to be the hazard switch. When turn signals stop working il press the hazard switch on and off (which only barely works), and then flip the stalk and the turn signals start working again somehow.
Thanks for the replies.
Old 08-20-2012, 10:28 AM
kernelPanicked
Hey Hunter83,
The forum emailed me when you replied so I came back here, and noticed the link I posted is now broken. Funny coincidence. I was able to salvage the PDF from Google's cache and I've added it to my Google Docs repo and shared it publicly. You can get directions for hazard switch replacement here:
https://docs.google.com/open?id=1vRH...I9nmuubSYQcuD1
Credit to Neil Kline for the writeup.
This worked for me. The only hard part was the step where you get the top snap loose by banging on the flasher with a screwdriver. For some reason it took me forever to get that to go. I think, in fact, I ended up getting in there somehow (wear gloves) and either snapping it or managing to pinch it with a tool. It took me a few tries, and it was when I first got the car so I kind of forget. Still, hours of fiddling with that is still easier than taking out the dash.
Old 08-20-2012, 04:34 PM
BigGun
BigGun's Avatar
Must be magic! Your first post said you had the switch replaced by the dealer and it did not fix the problem. "so I bought a brand new one from dealer and had them install it and blinkers still dont work."
I would suggest you do a little more trouble shooting instead of just replacing parts.
Old 08-20-2012, 04:40 PM
kernelPanicked
I was confused by that too, but I think he meant the stalk on the steering column. He said "blinker/headlight switch," so that is how I took it.
That said, you're right, thorough troubleshooting is always best!
Old 08-20-2012, 11:05 PM
BigGun
BigGun's Avatar
After reading the post again...You're Right. It was late in the day and I was on my out. Does sound like it may be the hazard switch since he has already replaced the stalk. I would still check for voltage and ground.
Old 08-20-2012, 11:47 PM
happiedazs
Support Corvetteforum!
happiedazs's Avatar
Don't foget to disconnect the battery first before fooling around with all those dash wires
Old 08-21-2012, 12:14 AM
Katherinejjm
Katherinejjm's Avatar
To Turn signals dont work
Quick Reply: Turn signals dont work
