Everyone that has had a leaking rear differential or tranny seal
If you have had an leaking rear end seal or tranny seal please post the year and miles when it first occured. I am curious if this is common for all c5 or just certain years or if it happens by miles. Also any mods that may have put more stress on these parts.
It appears that some have had an ongoing problem with this.
Re: Everyone that has had a leaking rear differential or tranny seal (123vette456)
2000 coupe, 3.15 A4, stock. Started leaking at approx 16,000 miles.
Dealer changed left case O-Ring. Solution remains sound today, 10 months later and now at 23,000 miles.
99 MN6 differential leaked about 24k fixed then tranny case leaked..fixed with complete rebuild...possibly leaking again at the case and if so WILL be fixed again under extended warranty :smash: this is ridiculous
Re: Everyone that has had a leaking rear differential or tranny seal (pewter99)
Differential leak mileage at the time 36,600. Fixed under extended warranty, it is leaking again!!!! :cuss Have to go back to the dealer, only mods I have exhaust and intake.
Just started leaking @ 8,000 miles and 18 months old.
Mods are exhaust and intake only.
At dealer as we speak. I've only found about four drops so far
but the driver's side of diff case is wet...GeorgeC
Cruising
Re: Everyone that has had a leaking rear differential or tranny seal (georgec114)
00 6spd coupe 24k. diff leaking. in pieces at dealership as we speak :cry . they say 2 days to fix.
no mods
[Modified by BlackandBlue, 11:22 AM 5/30/2002]
no mods
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
00 HT 30.000 Drivers side fixed about three weeks ago. Five now, I hope. :flag
Mine started with an occasional drop on the garage floor at about 12K. Got ALOT worse at around 33K when it started leaving spots all over the rear bumper after a hard drive. Got it fixed under warrantee at about 35K. Now at 50K it's still fine. I'm not even sure where the leak was, they pulled the whole driveline and re-sealed everything. The whole tranny/diff was wet when I took it in. It seemed to start on the drivers side however.
Gary
Gary
Re: Everyone that has had a leaking rear differential or tranny seal (C5GARY)
97 a4 started leaking around 32k miles, fixed at dealer, now at 35k it is leaking again both times drivers side.
Shawn
Shawn
I found diff leaking on right side at 11,500 miles. 15,700 miles now and still good. Here are some pics:
[Modified by gmblack3, 12:12 PM 5/30/2002]
Did a carrier swap at 65K, with a 12K carrier, driver side output shaft seal began leaking badly at 67K. Simple fix to replace side cover o ring and shaft seal. Glad it wasn't the seal plate between tranny, that would take a lot longer. Here's what I did to fix: http://forums.corvetteforum.com/zerothread?id=297199
Couldn't believe how porous the casting is, worm holes!
The only problem I had was after running 1/4 mile one night. Talked to my mechanic (a very good/trustworthy one), and he said that's somewhat normal when you run them hard for a while. Not sure this helps a lot - only one occurrence / one opinion. Never had a problem with everyday driving.
Mark :cool:
Mark :cool:
99 MN6 - tranny seal replaced @ 24,500mi on tuesday. Completely stock
-vanroth
[Modified by vanroth, 5:54 PM 5/30/2002]
-vanroth
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
7k miles....."porous casing"....whole pumpkin replaced :eek:
Re: Everyone that has had a leaking rear differential or tranny seal (NOT HRZ)
He does have a point. Mine wasn't leaking until I did some real hard pylon-type turns, so I figured I sloshed the oil up over the seal. That's probably why lowering the level is a sometimes fix.
Cruise-In III Veteran
Re: Everyone that has had a leaking rear differential or tranny seal (Stu in CA)
leaky when new. replaced tranny seal and rebuilt by dealer day two.
Re: Everyone that has had a leaking rear differential or tranny seal (jayleone)
Common problem from factory. Replaced by my mech at about 15k miles. No problems since. 32k now.
