Just changed tranny fluid and have grinded gears 3 times already..
As title states, I just changed the transmission fluid in my '01 Z06 with 48k miles.
I noticed an immediate improvement in the rowing of gears..much more silkier.
However: I've now grinded trying to go into a gear while driving around town three separate times. Not sure if it was any specific gear, and only one of the times was a spirited acceleration going into third gear. I've never had this happen before.
I used Mobil 1 Synthetic ATF.
:EDIT:
Car was level when I filled it. Shift box is and has been aligned. Problem hasn't happened again for the past few days, and was only evident the 2 days after the change.
:EDIT:
How's the fluid in your clutch's master cylinder?
I have found that I have to do the Ranger method every 3-4 weeks or so depending on how much or far I drive. It gets dirty pretty fast.
In the words of Paul Harvey.....and now...the rest of the story....
http://forums.corvetteforum.com/c5-t...t-box-pin.html
Making assumptions only leads to more problems, because it leaves possiblity on the table. No offense intended, but if you had the correct conclusions/answers, you would not be posting for help. Always give the forum members you solicit for help, the luxury of knowing everything you have done to the vehicle, whether you think it's related or not.
Well, obviously that's enough fluid, and my question regarding the clutch master cylinder reservoir, was along the line that maybe you're not getting full actuation of the cylinder.
Maybe you could better describe what you mean by "grinding", while going into gear. OTOH, maybe with your perception of the shifts going a little easier, without realizing it, you're also not depressing the clutch as far as necessary.
What cha' waitng for? I have just over 21K on my '01, and I just changed it for the second time....
Where...I used that for my diff, but are you suggesting I use that in the transmission?
Well, let's say I'm driving normally, revving no higher than 3K to shift, and randomly, while shifting into say third gear, the shifter doesn't go all the way into gear and so when I let off the clutch and give it gas it (pops out?) makes a loud grinding noise and I have to depress the clutch again and firmly put it back in gear. It has only happened 3 times, but that's a lot given that I've put 20K miles on my car since Christmas and have NEVER had that problem until I changed the fluid the other day. It's possible that I'm not depressing the clutch all the way or that I'm not firmly putting it into gear since I'm getting used to the easiness of the rowing due to the fresh fluid.. I'll keep an eye on it as I drive up to NC in a few moments.
Court's adjurned.
I had to replace my trans and this was the only oil that my mechanic would use. This is from RP web site.
SYNCHROMAX – MANUAL TRANSMISSION FLUID
Synchromax is a manual transmission fluid that increases performance and the life of your equipment. It improves shifting, reduces gear noise and increases power transfer to the wheels. It also lowers operating temperatures and provides outstanding wear protection for longer transmission life.
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid. It’s also ideal for 4×4 transfer cases and motorcycle gear boxes. Synchromax is fully compatible with all types of friction materials. It provides excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers.
Synchromax is formulated with Royal Purple’s proprietary Synerlec technology for unsurpassed performance and protection.
