A/c light blinking
1 Post
A/c light blinking
When I try to turn on my a/c I push the button and the light flashes and goes off. Someone told me it needs recharged but the fellas at autozone say that if the compressor won't come on the recharge bottle they sell won't work. Any advice. Thanks.
I'd add a can and see what happens. Mine did that once and was due to a leak, that it was basically empty. You could check if there's any pressure at the port by the firewall. Push the valve and see if there's any pressure in it. That will really only tell if it's completely empty, or not.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,, I have to DISAGREE with the AutoZone Guy.
My 02 ZO6 was a FULL can low and the compressor would NOT come on. Same BLINKING and NO WORK as what your seeing..
Boil some water and find a pail that you can set the can of 134 in. I installed the fitting on the LOW (SUCTION SIDE) pulled the trigger and the charge went in easily. As soon as the system had enough pressure in it, I turned on the compressor and finished charging the system. You can also shake the can to help the LIQUID R-134 flash to a gas. When the liquid flashes to a GAS, it raises the pressure in the can and will easily recharge the system.
Just DO NOT turn the can UP SIDE DOWN!!! That will inject liquid in to the gas side. That would be BAD!
MAKE SURE that you purchase a 134 recharge with OIL in it.
Bill
Bill
You can also temporarily jump the low pressure cutout switch to run the compressor
Bill
Bill
If the compressor won't run do to almost NO FREON in the system simply pull the connector off the low pressure cutout switch on the right front fender and use a paper clip or short piece of wire to allow the compressor to run while adding freon to the low pressure line.
1 Post
Well now the a/c light will blink again until the car has ran for 10 or 15 min. Then it stays on but blows hot air. I read online that it could take up to 26oz of r134. It was completely empty when I put it in and started getting cold. (18oz). Should I put some more in to fill it up? Or does it sound like ive got a massive leak somewhere?
Sounds like you have a nasty leak. Time to either take it to the professionals, or invest in some pretty spendy gear to fix it yourself (manifold gauges {$80}, vacuum pump{$150+}, leak dye and UV light or refrigerant sniffer{$?}).
Ususlly 2 12 or 14 oz cans are about right
thats about 2 12 or 14 oz cans
However, if he has such a bad leak that he lost ALL of his refrigerant, he needs to fix the leak and pull a vacuum on his system. As it is, there is moisture in his a/c system and when that mixes with the refrigerant it will create an acid and that will cause component failures sooner or later (plus, his charge won't last long, so it's silly to not fix the leak and just keep pumping refrigerant into the system).
Well, if you are going to try it yourself. Get some refrigerant with dye in it. Get the little yellow glasses and light that goes with it, check your AC system first by looking at the lines and connections in case there was already some dye in it. IF there is no dye visable, put the freon with the dye in and see where its leaking, or take it to a professional. Just my 2cents for what its worth. I agree with Trios, need a fix.
You are probably correct, but, he already added some so it wasnt empty,and had it running so? Is it really going to hurt it any more than he already did, and , really how many times does it take to hurt the system? I don't think that you keep adding, as thats stupid and costly, but he was up and running, with an obvious leak that he wanted to find.
How do the pros find the leak? Not being scarcastic, I really don't know? Maybe you can enlighten us on this? I am obviously not an AC pro, but I went through a lot getting my AC fixed, and just offering some ideas. Maybe someone on this forum can tell us exactly how to process this situation?
Refrigerant leaking out down not equal air getting in
When the pressurized refrigerant leaks out it does not mean that it is replaced with air. If there is a bad O ring or other place where the refrigerant seeps out then thats it. Air is not going to SEEP into the system. If you open the system by cracking open a fitting or removing a component then air could get in. If the leak is small there may still be a small amount of refrigerant in the system. Not enough to do any cooling but unless the car is in the vortex of a tornado the air is not going to get in.
