PUt in a UPF44 oil filter and now......
Re: PUt in a UPF44 oil filter and now...... (CRUZMISL)
I never noticed an increase in oil press. when using it in the past. I've been waiting for them to become available locally again and have a Mobil 1 in right now. Where did you get yours? Ken Fitchner or one of the forum vendors?
Re: PUt in a UPF44 oil filter and now...... (Tx99FRC)
I just put in a UPF44 oil filter today too. I'm not sure I see any change in pressure. Its hard to tell. I got my filters from LAPD. They sell them in boxes of 6. I put the other 5 in ziplock bags to try to keep them from getting contaminated or from moisture. Hopefully that will keep them from having any problems several months down the line.
- Mark
- Mark
[QUOTE]my oil pressure is higher. Anyone else notice this?
Since I've seen all the debate on oil pressure with the UPF44 and the oil capacity of the C5's, I paid careful attention when I did my first oil change.
The results - changed from 5w-30 to 10w-30 and from PF44 to UPF44. Absolutely no change in oil pressure at exactly the same RPM's (idle ane 2000), same oil & water temps. Also, I drained out exactly 7 Qts. and it took 7 Qts. to reach the MAX. hole on the dip stick. My car had 7 miles on it at delivery and did not receive the pre delivery prep. so I know the car came from GM with 7 Qts. I hope this helps :yesnod:
[Modified by JWD01, 5:19 PM 5/27/2002]
Cruise-In III Veteran
I change oil and filter at the same time, and every time I change the oil pressure goes up about 4psi. When I change the oil and filter the pressure is about 40 psi before and 44 psi after. UPF44 oil filter & Mobil 5w-30 oil.
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Re: PUt in a UPF44 oil filter and now...... (JWD01)
My oil pressure went up about 5 pounds across the board with the UPF-44.
Re: PUt in a UPF44 oil filter and now...... (Buckmaster)
UpF44 Compared to what? Unless we say what was in there before, than the info is meaningless. By the my oil pressure went up a little when I went from a Upf44 to a Mobil-1 filter.
Mine did the same thing when I changed the oil for the first time, using the UPF44 filter. The oil pressure has remained constant since then after each oil change with the UPF44.
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Re: PUt in a UPF44 oil filter and now...... (gasman29)
New oil on its own can increase the oil pressure for awhile until it gets broke in. I definitely wouldn't worry about it. What PSI are you running during warm-up? What about at cruising speeds on the highway?
I noticed an increase in oil pressure when I changed my oil for the first time. I don't drive the car very much (<3000 miles on a 2000 model), so I have only changed it once. I also noticed that the original oil was very thin.
