Bose auxiliary input location?
My factory stereo has an Aux input button on it, but I do not see where the input jack is. Unfortunately the owners manual is missing.
Can someone tell me how to use the Aux input with my Ipod?
Thanks a ton in advance.
http://forums.corvetteforum.com/audio-electronics-20/
How does one find the sub sections of this forum?
That is for a factory CD changer; however, there are custom adapters to facilitate the use of an ipod.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Go to the FORUM tab, then to the C5 GENERAL CORVETTE and under general corvette you will see AUDIO/ELECTRONICS
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I added the 12 dish changer to my 02 Z and there are TWO connectors in the passengers foot well. One for POWER and one for input/output. Look under the carpet near the right side of the passengers fuse box. One cable will be taped to the other so it will look like only ONE cable. You will need a COHAR cable to run it to the rear of the car. I guess they make a cable that will allow you to connect it to other things:
