FAST 92 Intakes are back! In black!
Old 07-05-2012, 05:01 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default FAST 92 Intakes are back! In black!
FAST LSX 92mm Intake Manifold (LS1/LS2)
In stock!
Part# 54039B
The BLACK version of the FAST LSX 92mm Intake Manifold delivers proven bolt-on performance gains with a clean eye-catching appearance.
The patented LSX™ 92mm Black Intake Manifold from FAST™ is the only three-piece Gen III (cathedral port) composite manifold proven to deliver increased performance without compromising bottom-end drivability or high RPM power. For both street and racing applications, the new black intake manifold is an easy bolt-on installation for GM Gen III (LS1, -2 & -6) engines and is designed to work with the FAST™ Big Mouth 92mm Throttle Body™. The FAST™ LSX™ 92mm Black Intake Manifold maintains the performance gains achieved over stock intake manifolds with no loss in drivability or low RPM torque. While the FAST 92 intake manifold delivers terrific performance right out of the box, it can be ported by the customer for even more flow. As requested by previous LSX™ customers, the intake features the added benefits of corrosion-free stainless steel assembly bolts, an improved throttle body sealing flange and o-ring gasket and threaded insert throttle body mounts that provide increased durability.
Features & Benefits:
•New “Black” Gen III intake manifold with 92mm throttle body intake opening & added refinements
•Improved throttle body sealing flange & o-ring gasket
•Includes stainless steel bolts, threaded insert throttle body mounts & mounting hardware
•Incorporates high-quality polymer materials, which resist “heat sink” effect of aluminum
•Maximizes potential of other popular engine performance upgrades such as cylinder heads
•Designed to work in conjunction with the new FAST™ Big Mouth Throttle Body™ (92mm)
Part# 54039B
Old 07-07-2012, 01:26 AM
Wadoka
Wadoka's Avatar
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Now you've gone and gotten AC/DC stuck in my head... thanks.
Guess I'll have to go for a drive.
Old 07-09-2012, 02:26 PM
0HinsonSuperCars
Former Vendor
Old 07-12-2012, 04:09 PM
MStrahan
MStrahan's Avatar
Thanks for the quick shipping guys!
Old 07-16-2012, 10:18 AM
0HinsonSuperCars
Former Vendor
Old 11-06-2012, 11:55 AM
NukeC5
NukeC5's Avatar
Ordered one by phone last week. Thanks Seth
Old 11-06-2012, 08:18 PM
Must_Have_Z
Must_Have_Z's Avatar
Ordered mine today, woohoo!
Old 12-06-2012, 11:40 AM
0HinsonSuperCars
Former Vendor
Old 12-06-2012, 02:16 PM
Johnz02Z06
Support Corvetteforum!
Johnz02Z06's Avatar
St. Jude Donor '14
What gains should I expect from the FAST 92 and your 92mm TB on a stock 2002 Z06 with A twin cone intake and BORLA XR-1 exhaust.
Old 12-06-2012, 02:23 PM
NukeC5
NukeC5's Avatar
Going from a LS6 intake and p&p tb (tuned) on my 99 coupe, to a FAST 92 and LS2 picked up 15whp. Should be 15-20whp for you if your car is tuned. If not, probably closer to 25-30whp.
Old 12-06-2012, 03:49 PM
Johnz02Z06
Johnz02Z06's Avatar
St. Jude Donor '14
Default Tune
I have never had the car tuned. So would you say maybe even more once I install it and then tune? Being the manifold would be off...how much more time would be needed to do a cam change too?
Old 01-09-2013, 10:30 AM
0HinsonSuperCars
Former Vendor
Having the intake manifold off won't help with the camshaft labor.
Old 05-09-2013, 04:53 PM
0HinsonSuperCars
Former Vendor
Thanks for your orders!
To FAST 92 Intakes are back! In black!
Quick Reply: FAST 92 Intakes are back! In black!
