Ragin Racin Stage 1,2,3,4 "SALE"
Supporting Vendor
Ragin Racin is offering a parts package for all performance levels. All the parts you need to bring your performance up to your desired HP levels. Put a little Rage in your Vette, Remember "If you're not Ragin you're not Racin"!!
Stage 1
Honker CAI
Ragin Racin ported intake and throttle body*
160 stat
$725 Z06 add $100
Stage 2
Honker CAI
160 stat
Long tube headers
$1765 Z06 add $100
Stage 3
Honker CAI
160 stat
Long tube headers
Ragin Racin cam of your choice
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
2 water pump gaskets
Crank seal
2 valve cover gaskets
$2895
Stage 4
Honker CAI
160 stat
Long tube headers
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
Crank seal
Ragin Racin ported heads*
head bolts
2 head gaskets
$3850
For details please call 337-278-8397.
* We port your core.
__________________
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
Stage 1
Honker CAI
160 stat
$725 Z06 add $100
Stage 2
Honker CAI
160 stat
Long tube headers
$1765 Z06 add $100
Stage 3
Honker CAI
160 stat
Long tube headers
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
Crank seal
$2895
Stage 4
Honker CAI
160 stat
Long tube headers
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
Crank seal
head bolts
2 head gaskets
$3850
__________________
Randy Leger
337-278-8397
Supporting Vendor
Cam choices:
LS 1,2,6 Camshafts
Stinger 224/232 .625/.625 113 1800-6800 rpm powerband Exlellent low end torque and midrange power with excellant street manners.
Undertaker 224/232 116 Off idle-6800 rpm power band Stock drivability with a very minor lope. Excellant stealth or blower cam.
LS1 Blower 220/230 114 Off idle to 6800 rpm very nice idle and drivability to maximize performance inr boosted lsx.
Shreader 228/236 113 2400-6800 rpm powerband Excellant midrandge cam with decent drivability. Choppy idle.
Distroyer 232/242 112 2800-6800 rpm power band Great top end power. Some surging at lower rpm's. convertor required.
LS3
Intimidator 224/240 113 1800-6800 powerband excellant low end and with a good top end punch. Real good drivability. Nice choppy cam idle. No convertor needed.
Avenger 228/244 112 2000-6800 rpm powerband Great mid range
and top end power. Choppy idle Convertor required.
LS7
Sleeper 222/242 114 off idle to 6800 rpm powerband Excellant torque Like stock drivability very mild idle.
Stalker 224/246 115 1800-6800 powerband excellant power through out great drivability Choppy idle
Lethal 232/250 113 2400-6800 rpm powerband Excellant med range with a great top end punch. Minor low rpm surging. Nice choppy cam idle
Punisher 236/256 111 2800-6800 rpm powerband Good mid range and excellant top end power Very choppy idle
Striker 240/260 109 3000-7000 rpm powerband Great top end punch very choppy idle
Blower 1 224/248 117 Very efficient with slight cam sound to idle Stock drivabilty
Blower 2 232/256 114 Choppy idle for larger blowers Some surging at lower rpm's
LS9 ZR1
ZfoRce1 224/250 115 nice choppy idle with good drivability
LS3
LS7
LS9 ZR1
Supporting Vendor
Supporting Vendor
We are now operating at new facility!!
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 282KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 281KB.
