Right Rear Solenoid Circuit Open
Hello, I have a dic error code C0594, which is the RR Solenoid circuit open. Where should I start with this error code on the car?
Ok here we go...
I assume you have a 2003-2004? Equipped with F55 suspension. (The switch on the console that says Tour/Sport)
This code may be the beginning of the end for your suspension, or a simple fix. Best case the connector came off the top of the shock for some unknown reason. Worst case the shock or controller has failed and require replacement. Have a look at the connector and harness and report back.
Co594 HC
Pulled the connections off the shock and cleaned. Was not dirty.
Now I have a new error code, 10-PCM PP1280 HC.
Any ideas what to check futher?
All checked out and looked good, cleaned and re-connected back.
A new code has now appeared, 10-PCM P1280 HC,
Where do you think I should check now?
