Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-14-2012, 09:10 PM   #1
Bob Chapman
CF Senior Member
Bob Chapman's Avatar
Default Rear end whine
My 2002 6 spd.with 82000 miles is developing a whine from what seems to be the rear. I get it above 60mph and when the drive system is slightly pulling but not on acceleration or deceleration. Happens in 5th and 6th gear. Put Red Line fluids in tranny and differential about 30.000 miles ago. The whine seems to be getting slightly louder over time. It's not loud - just annoying and new. Ideas?
Bob Chapman is offline   Reply With Quote
Old 05-14-2012, 09:53 PM   #2
Rick@RKT56
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14
Rick@RKT56's Avatar
pages/RKT56/244463478927497 rktperformance
Quote:
This is a classic symptom of ring and pinion gears making noise. The noise happens around 65-70 mph in overdrives. If you can't live with it, time for new gears.
__________________
Rick@RKT56 is online now   Reply With Quote
Old 05-14-2012, 10:19 PM   #3
Roc87
CF Senior Member
Roc87's Avatar
Most likely will get louder as well Mine took around 3k miles to go from a slight hum to downright annoying and not being able to use the radio to cover the noise.
Time for 3.90s from Rick (see above)
__________________
-Eric
'01 Vette - "FRV - Fixed Roof Vert", Z06 Sways, C6Z Shocks, Z16 rims, Hurst Short Throw, Vortex Intake, "Sycho"Tune, AR Headers, B&B PRTs, RKT56 built 3.90 diff. - 337RWHP/350Ft.lbs; 13.6@106 w/ 7100'D/A
'87 Astroroof GNX Clone - 156k miles, STOCK Engine (Minus Timing Set & Springs) With A Few Bolt Ons, 422RWHP/502Ft.lbs 1.73(60') 7.40(8th) 11.55@118 w/ 91 Oct. & ALKY. Now in TimeOut for a spun rod bearing
Roc87 is offline   Reply With Quote
Old 05-15-2012, 12:56 AM   #4
NewWorldBlues
CF Member
Does it start off as a low high-pitched frequency sound?
I've notice this on the used 3.42 diff that was just put in. Only under load.
NewWorldBlues is offline   Reply With Quote
Old 05-15-2012, 11:07 AM   #5
Rick@RKT56
Supporting Vendor
Rick@RKT56's Avatar
Most gear whines are on the load (accelerating) side. Usually the noise is gone during coasting or decel. The noise is similar to a straight cut gears in a transmission.
__________________
Old 06-02-2012, 10:32 PM   #6
Z28STYLE23
CF Senior Member
Z28STYLE23's Avatar
chris bour
I'm getting a similar whine that starts at 50mph. is the fix just new gears?
Z28STYLE23 is offline   Reply With Quote
Old 06-03-2012, 11:25 AM   #7
Rick@RKT56
Supporting Vendor
Rick@RKT56's Avatar
Quote:
Yes, but I would check to make sure it's not a rear hub noise first.
__________________
Old 06-03-2012, 10:03 PM   #8
ALLEGRO
CF Senior Member
ALLEGRO's Avatar
Both my Trans Am GT and my C5 Anniversary Edition (both with T-56 and 3.42 gears) have whinned at highway speeds. Seems I was told that it was the tranny that was the culprit, but I cannot remember. Mine have not increased in volume ever, so I am just going to live with it.....or turn the stereo up louder. LOL
__________________
2003 50th ANNIVERSARY EDITION
CLICK PICTURES TO ENLARGE
ALLEGRO is offline   Reply With Quote
Old 08-20-2012, 07:49 PM   #9
texasEBz06
Junior Member
texasEBz06's Avatar
im having a gear whine also in my 02 z06 , it starts at any speed when im on throttle, if im on the floor with the throttle it goes away, if Im just cruizing I hear it more often.
texasEBz06 is offline   Reply With Quote
Old 08-21-2012, 03:07 AM   #10
NukeC5
CF Senior Member
NukeC5's Avatar
Yes the ring and pinion are the cause. I swapped a 3.42 diff out of a Z06 into my 99 A4 and found out why they removed it. It whines badly all the time. If you can live with it, it doesn't hurt anything. If not, upgrade time
NukeC5 is offline   Reply With Quote
Old 08-21-2012, 05:19 AM   #11
_r2h
CF Senior Member
_r2h's Avatar
https://www.facebook.com/profile.php?id=1214640063 Bradley-Heikes
Send a message via Skype™ to _r2h
Quote:
I have a noise that is kind of opposite of this. Most noticeable on cruise, only slightly noticeable on acceleration, completely gone on deceleration. All after it's warmed up and at operating temp. I haven't figured it out yet.
_r2h is offline   Reply With Quote
Old 08-21-2012, 11:19 AM   #12
Rick@RKT56
Supporting Vendor
Rick@RKT56's Avatar
Quote:
I should have been more specific. The noise is most evident on part throttle acceleration (10-30% throttle). The noise disappears under hard acceleration and decel.
__________________
Old 08-26-2012, 09:52 AM   #13
striper
CF Senior Member
striper's Avatar
I've had this noise for thousands of miles and it doesn't hurt anything. It's not too bad so I haven't done anything about it. I've got 108k miles and it has never gotten any worse.
striper is offline   Reply With Quote
Old 08-26-2012, 01:24 PM   #14
Dennis Wilson
CF Senior Member
Dennis Wilson's Avatar
My 3.90``s have been whining for over 30,000 miles now, loudest at 50-65 mph. sometimes louder than other times but not getting any worse. last diff change no metal in old oil so I`m living with it.
Dennis Wilson is offline   Reply With Quote
Old 12-22-2012, 11:15 PM   #15
Rob 99
I'm "Apache" a psycho dog
Support Corvetteforum!
Rob 99's Avatar
Why does this happen? and in my case only or mostly in 6th gear?
not enough 'load' on the gears,
geez i only have 40,000 mi (2004 year ) and it's been getting worse very annoying like others have said.
Rob 99 is offline   Reply With Quote
Old 12-23-2012, 11:02 AM   #16
NukeC5
CF Senior Member
NukeC5's Avatar
They say its from improper backlash of the ring and pinion. I find it had to believe that so many mistakes were made from the factory as this happens to so many people. I think that hard driving and abuse causes the gears to form a bad wear pattern. An improper break in and or allot of spirited driving will wipe out the gear teeth surface and make them noisy.
Old 12-23-2012, 12:00 PM   #17
Rick@RKT56
Supporting Vendor
Rick@RKT56's Avatar
Quote:
This particular diff was whinning and the ring and pinion gears just ate each other up. This magnet was the result.
Click the image to open in full size.
__________________
Old 12-23-2012, 03:58 PM   #18
_r2h
CF Senior Member
_r2h's Avatar
Wow, sweet example of a magnet's lines of force.
Old 12-23-2012, 07:10 PM   #19
Ozzysezit
CF Member
Ozzysezit's Avatar
NukeC5
Im not sure that "spirited" driving would be the cause of this. It is a Corvette after all and spirited driving is what the car was made for. I am new to this forum but I have been doing alot of research on the C5 Vettes. A Corvette with 40k miles on it should not have gear noise (unless maybe they ran it dry of lube at LeMans) I think maybe this was a Factory flaw that went unnoticed.
Ozzysezit is offline   Reply With Quote
Old 12-24-2012, 11:48 AM   #20
NukeC5
CF Senior Member
NukeC5's Avatar
Quote:
Originally Posted by Ozzysezit View Post
NukeC5
It may be in some cases, but if you stick around this forum awhile you will find that gear noise is a problem for way to many C5 owners to be factory flaws. The words "spirited driving" to me and (and "allot of spirited driving" at that) to me means the guys that are constantly on the throttle or brakes. The gears never have a chance to form a smooth wear pattern which leads to a surface that whines.
The Corvette is still a car made from the same parts as any other Chevy V8. Harsh driving will lead to owning a harshly driven car that shows it like any other car.
Reload this Page Rear end whine
Tags
390, 60, c5, c6, corvette, loud, make, mph, noise, rear, rearend, slow, sound, speed, whining, winding, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
