What's Inside Your 97-00 ABS Module (Photos)
mrr23 (10-08-2015)
mrr23 (10-08-2015)
mrr23 (10-08-2015)
mrr23 (10-08-2015)
mrr23 (10-08-2015)
#86
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive had one a part and If its bad,, NOPE,,, STICK A FORK IN IT,,,,,,Its DONE!
The carbon resistance ribbon that the tiny pick off follower fingers use to pick up the position of the steering wheel signal wears off and you can fix that!
Its also sonic welded together I got it apart but quickly figured out, a new one was in order.
BC
BC
mrr23 (10-08-2015)
#88
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Are you refering to "DELPHI" ???
Delphi is the manufacture of most of our electronics stuff.
mrr23 (10-08-2015)
#89
Nope. "dolphin" was, or is a waterproof sealer for circuit boards. It is what MSD uses, or used, on their units. It can be cut and or peeled off but I remember someone telling me that alcohol, IIRC, would remove it.
mrr23 (10-08-2015)
#90
Chuck are you saying this should be a similar fix for the Non-Active Handling ones too?
Thanks,Matt
Thanks,Matt
mrr23 (10-08-2015)
#91
I will talk with Chuck and Bill.
Thanks,Matt
mrr23 (10-08-2015)
#92
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The EBTCM or EBCM depending on what service manual year you have fail in two distinct ways
POWER/GROUND & LOGIC
What Chuck repaired was a power issue. The module logic worked fine BUT,, it was unable to apply that control power to the MAGNASTEER COIL due to the burnt contacts in the relay
Same would be true for the other relay. That relay supplies power for the solenoid valve coils.
IF,, there is a logic issue (and thats the microprocessor under the green circuit board) Stick a FORK in it cause its DONE!
Thats not saying that there couldn't be an issue with the male and female pins that interconnect the EBTCM and BPMV.. That would need to be investigated.
Any electrical issue on that green board that is easily removed from the module should be repairable..
Relays that control high current applications frequently fail because of damaged power output contacts. They get burnt and pitted and unable to supply the proper current and voltage output/
When ever you have an issue with ANY module,, always check all the input power and and grounds to that module. Make sure that your getting FULL battery voltage to all the 12 VDC supplies. Especially the ignition switch supplied power.
Bill
Bill
mrr23 (10-08-2015)
#93
I'm going to resurrect this old thread because I have an intermittent issue with my 2000 non-active handling FRC. sometimes I get the lights at start up in the morning, say once very two week. Shut the ignition off and it goes way and works fine for another couple weeks. Also, sometimes at 79 MPH I will get the lights, same fix, turn off the ignition and it goes away.
My thoughts about this is that the Chinese can copy/reverse engineer ANYTHING. they've done it with just about anything right up to high tech military equipment and missile tech.
I don't know about the costs involved or where exactly you find these people in China, but perhaps a known good unit could be sent over to be reverse engineered.
I may just be talking out of my buttocks here but I just thought I'd throw it out there for discussion.
mrr23 (10-08-2015)
#94
mrr23 (10-08-2015)
#95
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Anyone have any more NEWS on 97-2000 EBTCMs??????? This post has been quiet for a while.
TTT
Bill
TTT
Bill
mrr23 (10-08-2015)
#96
Bill,
I lost my job of 37 years back in October. I no longer have the fancy tools to poke around inside one of these.
I really hoped we could dissolve the clear gel and troubleshoot the capacitors on the substrate. Those could at least be checked for shorts, a reasonably common failure.
They walked me and others out the door. I'm not even sure I still have that unit.....
Ron
Ron
mrr23 (10-08-2015)
#97
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill,
Ron
Ron
Ah man,,, I'm terribly sorry to hear that. That sucks.
Have you been able to find another job?
Hope things turn out for the best.
Bill
mrr23 (10-08-2015)
#98
It's ok. I'm 59 so just a few months from the 401k funds.
I'm in "ok" shape there.
I'd love to find a part time job working on hot rods or vettes. There are a couple of swamped shops here. But right now, I'm enjoying driving the C5 and racing the Nova.
Ron
mrr23 (10-08-2015)
#99
Joe zayas
Hey guys,
Marc @ Vettenuts was kind enough to send me a dead unit to take apart and play with.
I heard about potting, can't get them apart etc. So I took this one apart.
The board is held in with 2 screws and is soldered to 2 connectors. The upper one brings in power from the car to the board and the lower one is the output to the solenoids. A little tricky to unsolder unless you are an electronics geek like me.
Board Removed
Underneath is where the magic happens. And is also the world I live in professionally. Pretty cool.
The large white circuit is a ceramic hybrid. It contains surface mount caps, one 8 pin IC, and a few surface mount resistors. It also contains a lot of printed resistors that are laser trimmed for value. They are actually part of the raw hybrid.
The large square shiny items are flip chip IC's. A flip chip has the connections on the side you can't see, and are actually solder bumps that are reflow soldered to the hybrid. The black stuff that looks like it is running out from underneath is called underfill. It essentially seals the connections, helps transfer heat to the substrate.
The wires coming off each end of the hybrid to the connectors are welded aluminum wires that bring the signals and power in and out.
This is a multi layer substrate. There are traces (wires) inside that you can't see.
Another thing you can't see, and what is causing the picture to be a tad blurry, is the clear silicone type potting compound covering the entire surface. It is very pliable. I can poke at the wires right through it. Think of clear jello! Very strange. This covering keeps all moisture out, and helps the unit withstand vibration.
Even though it is 12-15 years old technology, it's pretty high tech ****. In todays world, components are smaller, and the IC's more dense.
The printed circuit board is very conventional. Caps, diodes and relays. The high power side of the unit.
So, the big question. Can it be fixed?
Everything on the external board can be tested. Could get lucky and find something bad. It is actually pretty simple. If all those parts are good........going to be real difficult to repair the hybrid.
Other than the welded connections, without a schematic....good luck there.....I'm going to have to say no. Not unless someone from GM kicks out the schematic and test procedure for the built hybrid.
Enjoy the photo!
There are some numbers on this unit.
ABS-5/TCS/MSVA2
Delphi 09356961
6961 92010251
The one on my 2000 says TCS/AH, so my guess is the one in the photos is not an active handling unit ????
Marc didn't tell me what it came from.
I hope the steering wheel sensor is a lot less complicated.
Ron
Board Removed
Enjoy the photo!
ABS-5/TCS/MSVA2
Delphi 09356961
6961 92010251
Ron
mrr23 (10-08-2015)
