What is the best way to remove spark plug boots ??
Old 04-25-2012, 12:05 PM
happiedazs
Support Corvetteforum!
happiedazs's Avatar
Default What is the best way to remove spark plug boots ??
In looking over how the coil is connected to each spark plug and I could use some guidance in how to remove the spark plug boot & metal can from the plug. Does the metal can come off first and then the rubber connector or do the come off together? Is there a special tool someone could recommend that will make removal of the metal can heat insulator and rubber boot easier then just yanking on everything --- there must be
Does the tool grab the metal can --- or go in between the metal can and rubber or just grab the rubber part. Here is what I am looking at
Thanks for your guidance here.
Old 04-25-2012, 12:06 PM
dougbfresh
dougbfresh's Avatar
Many different techniques, I used channel locks, DO NOT DESTROY THE CANS, you'll need them for the new wires.
Old 04-25-2012, 12:21 PM
corvettebob1
corvettebob1's Avatar
The only tools you need are your fingers, grab the boot at the top and twist it back and forth until its free.
Then pull it off the plug that's what I do, yes I know it's a pain in the a$$ but it's better then $50.00 for new wires every time you pull the plugs for some reason.
Old 04-25-2012, 12:25 PM
dougbfresh
dougbfresh's Avatar
I put a silicon dielectric on my boots when I put them on so they come off easy when I need them to.
Old 04-25-2012, 12:27 PM
mchicia1
mchicia1's Avatar
Pull the plug off the coil pack first, then grab the metal cover and spin the boot a 1/2 turn or so to break it loose. Then grab and wiggle it loose.
Old 04-25-2012, 02:46 PM
dougbfresh
dougbfresh's Avatar
If the wires have been on a long time with no dielectric, you WILL destroy one or more wires getting them off, have a new set ready.
Old 04-25-2012, 09:21 PM
cookie7
cookie7's Avatar
YESSiR been there done that
Old 04-26-2012, 12:23 AM
yaknow
yaknow's Avatar
Old 04-26-2012, 01:41 AM
Old Horsepower
Old Horsepower's Avatar
Or just put in some new wires. MSD 8.5mm Super Conductor Spark Plug Wires are on sale once in awhile. That way you can just rip those old ones out and feel good you have new wires and plugs. That's what I did and it does start and idle better. I did try to save the old ones but just too much effort. I ruined a few anyway.
Old 04-26-2012, 08:58 AM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
The metal heat shields and plug boots should both come off the spark plug together, as a single unit.
Old 04-26-2012, 11:37 AM
SaberD
SaberD's Avatar
I would suggest wearing mechanics gloves. they have some nice grip to them and will protect your kuckles when it pops loose.
Old 04-26-2012, 11:59 AM
Baldfart
Baldfart's Avatar
This is true. I just done mine a couple weeks ago and grabbing on to the heat shield with a small needle nose vise grip and pulled them off. Worked well for me me and did almost no damage to it.
To What is the best way to remove spark plug boots ??
Quick Reply: What is the best way to remove spark plug boots ??
