Not a lot of info for you, but something is making a "squeeky noise"?
Old 04-16-2012, 11:25 AM
aggiedave98
aggiedave98's Avatar
Default Not a lot of info for you, but something is making a "squeeky noise"?
My '03 Vette is making a squeeky noise at slow speeds. I can't pinpoint it, but it seems like it has something maybe to do with steering or suspension. It's almost like something is flexing without lubrication. I know this isn't much info for you guys, but I figured I'd throw it out there.
Old 04-16-2012, 03:40 PM
jedblanks
jedblanks's Avatar
Is it when you go over bumps?
If so it's more than likely the sway bar bushings. You can lube them or use Teflon tape between them and the sway bar.
If it's a rotational squeaking, look at the wheel bearings.
If it's a body flex squeaking, look at the top rear hatch hinges and lube them. They are right next to your head when you are driving.
Old 04-16-2012, 06:57 PM
zeevette
zeevette's Avatar
It could also be your serpentine belt tensioner pulley that's squeeking. I replaced mine when it was only 3 yrs. old. This is the best I could do with limited information.
Old 04-16-2012, 07:35 PM
Grimlock
Grimlock's Avatar
I am guessing it is a bushing of some sort. If you have aftermarket sway bars, then these would be the most likely area.
Old 04-23-2012, 11:00 AM
aggiedave98
Sorry for the delay but I wasn't able to figure out any more info until the past couple of days. I'm pretty sure it's my seat!!!! Crazy, huh? I would hear the noise during cornering and accel/decel maybe so I thought it was a bushing, etc. but realized I can make it happen at a stop by kind of rocking my seat back and forth and/or sideways. The good news is its probably just annoying versus a serious issue. But, any idea what I need to lubricate and with what?
Old 04-26-2012, 11:30 AM
aggiedave98
Any comments?
To Not a lot of info for you, but something is making a "squeeky noise"?
Quick Reply: Not a lot of info for you, but something is making a "squeeky noise"?
