Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2012, 10:23 PM   #1
fotoboy
CF Senior Member
fotoboy's Avatar
Default Converting to a mn6 from a mn12
I have a buddy w a c5zo6 w a 441 ci putting down around 580 to the wheels. He is looking to convert to a mn6 for road racing. What all is involved with converting to a mn6 from a mn12?
fotoboy is offline   Reply With Quote
Old 04-22-2012, 10:39 PM   #2
8VETTE7
CF Senior Member
8VETTE7's Avatar
Quote:
The ONLY difference is the gear ratio's. If you have access to a good Mn6 just swap tranny's. It's a simple swap. If you want to just swap gear then it gets to be fun since you get to disassemble the box.
Here is the gearing:
........MM6...............M12
1st ....2.66...............2.97
2nd....1.78...............2.07
3rd....1.30...............1.43
4th....1.00...............1.00
5th....0.74...............0.84
6th....0.50...............0.56
Rev....1.91...............3.28
8VETTE7 is offline   Reply With Quote
Old 04-23-2012, 07:49 AM   #3
AU N EGL
CF Senior Member
AU N EGL's Avatar
Not a big deal. many guys take out the MN12 for an MN6 or have it rebuilt
RPM trans can do it.
But use a .84 5th gear and a .75 or .6 for 6th gear
Dog rings are nice too, no lift shift
AU N EGL is offline   Reply With Quote
Old 04-23-2012, 11:09 AM   #4
jjtoma
CF Senior Member
Support Corvetteforum!
jjtoma's Avatar
For a road racer, should look at the ZR1 gear ratios also:
ME2 --------2012 stock
1st - 2.26
2nd - 1.58
3rd - 1.18
4th - 1.00
5th - 0.71
6th - 0.50
MH3----------2009-2011(2012 w/ PDE)
1st - 2.29
2nd- 1.61
3rd - 1.21
4th - 1.00
5th - 0.81
6th - 0.67
I think these are correct, best to call RPM Transmissions for answers
IMHO
Jim
jjtoma is offline   Reply With Quote
Old 04-23-2012, 11:27 AM   #5
ysb02
CF Senior Member
If I get my MN12 refreshed I'm going with MN6 1-4 and MN12 5-6 gears. Not interested in pulling 200mph in 5th, I'd rather have useability.
ysb02 is offline   Reply With Quote
Old 04-23-2012, 12:54 PM   #6
AU N EGL
CF Senior Member
AU N EGL's Avatar
ZR1 gear ratio is too close together for that much HP
Old 04-23-2012, 01:10 PM   #7
Tech
CF Senior Member
Tech's Avatar
Funny that GM put the MN12 in there to make the car seem more like a track car. Then, the track guys take it out in favor of the Coupe transmission. Are the guys doing the swap still around the same power level as stock?
Tech is offline   Reply With Quote
Old 04-23-2012, 01:59 PM   #8
Rick@RKT56
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12
Rick@RKT56's Avatar
pages/RKT56/244463478927497
First of all, let's get the RPO's right.
MN6 is the code for the manual transmission option.
MM6 is the 2.66 first gear T56.
M12 is the Z06 2.97 first gear T56.
Quote:
The M12 AND MM6 share the EXACT same 5/6 gears. The difference in ratio is the head gear reduction and NOT the 5/6 gears.
TR6060 transmissions can be set up for any combinations on the overdrive.
__________________
Rick@RKT56 is offline   Reply With Quote
Old 04-23-2012, 02:10 PM   #9
AU N EGL
CF Senior Member
AU N EGL's Avatar
Quote:
YES. the Zr1 gear ratio ( modeled after the GM Motorsports gear box) would be the ideal choice for a road course with a 3.73 or 3.90 gear.
On the ZR1 it is also very good, but north of 580 to the ground, that is wheel speed or could be in each gear
Hell I only run 400 to the ground and I can wheel speed in 3 gears.
the MN12 was to get better Zero to 60 times, the MN12 3-4 is a great combo, but the 2-3 is too much of a jump.
part of the other challenge is with the MN12, 3rd is too high for many low speed corners,but 2nd is too low, where the mn6 3rd is just a better gear for many corners.
Reload this Page Converting to a mn6 from a mn12
Tags
2003, 373, drag, gear, mn12, speed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
