Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-17-2012, 08:25 PM   #1
ANGRY Z
CF Senior Member
Support Corvetteforum!
ANGRY Z's Avatar
Default How do you remove the timing set crankshaft gear? And install it?
I am putting a new timing set on my new short block, but was wondering how the heck you are supposed to pull the timing set crankshaft gear off without damage? (pic is of my old block) And more importantly, how do I install the new one without damage to my new crank and new timing gear?
Click the image to open in full size.
__________________
650rwhp/590rwtq, ProCharger D1SC @ 9psi, Fully Forged 427, WCCH upgraded heads, ECS Stage 1 fuel system, 72 lb/hr injectors, Kenne Bell BAP, LG PRO Longtube headers/Off-Road X-pipe, B&B Fusion Exhaust, 102mm FAST LSXR intake manifold, McLeod RXT twin disc, DSS Stage 3 axles, ported/polished TB, MGW shifter, Tune by Tracy@TunersInc in Orange Park, FL. (YouTube channel -ANGRY6LITER for vids)
ANGRY Z is offline   Reply With Quote
Old 04-17-2012, 08:45 PM   #2
ANGRY Z
CF Senior Member
ANGRY Z's Avatar
OK. I have no idea how this posted in C5 tech. Moderators please move to C6 TECH.
Old 04-17-2012, 09:14 PM   #3
ANGRY Z
CF Senior Member
ANGRY Z's Avatar
This is a C6 Z06 LS7.
Old 04-17-2012, 09:35 PM   #4
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Likely same tools as used for LS1
Removal tools
Removal
Installation
vettenuts is offline   Reply With Quote
Old 04-17-2012, 10:14 PM   #5
ANGRY Z
CF Senior Member
ANGRY Z's Avatar
Nice. Where did you purchase these tools?
Old 04-18-2012, 05:29 AM   #6
vettenuts
CF Senior Member
vettenuts's Avatar
fleabay, they are the Kent-Moore factory tools.
Old 04-18-2012, 07:49 AM   #7
ANGRY Z
CF Senior Member
ANGRY Z's Avatar
Quote:
Sweet. Thanks!
Old 04-18-2012, 09:23 AM   #8
RonSSNova
CF Senior Member
RonSSNova's Avatar
I made one with a piece of 1/8" steel, a hole saw, and a drill and tap.
Doesn't look pretty like that, but worked fine. You can use your old part to tap on the new one.
Ron
RonSSNova is offline   Reply With Quote
Old 04-18-2012, 10:27 AM   #9
printmanjackson
CF Senior Member
St. Jude Donor '06-'07-'08-'09
printmanjackson's Avatar
Neal Maners
Ron
tap?
printmanjackson is offline   Reply With Quote
Old 04-18-2012, 05:54 PM   #10
ANGRY Z
CF Senior Member
ANGRY Z's Avatar
Ron
Bearings would not like being tapped. I'll stick with the the threaded press on method.
But I am having trouble finding these tools on ebay...
Old 04-18-2012, 10:30 PM   #11
tony75A
CF Member
I used a three jawed puller to remove. Then made my own installation tool out of threaded rod stock with a nut welded on the end. Then I use an old bearing race and nut to do the actual pressing into place.
tony75A is offline   Reply With Quote
Reload this Page How do you remove the timing set crankshaft gear? And install it?
Tags
99, corvette, crank, crankshaft, gear, install, lower, ls1, pull, pulling, remove, replace, set, shaft, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
