steering column locked
Old 07-08-2020, 02:55 PM
Rick Dutot
Rick Dutot's Avatar
Default steering column locked
I have a 2002 manual corvette with a locked steering column problem. I know there are different products you can install to eliminate this problem . I was wondering if this problem can be eliminated without installing any bypass items. My car has already been in the shop in 2004 with the recall. Thank you.
Rick.
Old 07-08-2020, 03:16 PM
k24556
Support Corvetteforum!
k24556's Avatar
buy an lmc5. That is a sure fire cure
Old 07-08-2020, 03:31 PM
k24556
k24556's Avatar
if it is locked now, there is a trick that will only work a few times to get it unlocked. What you do is start with the ign key in the off position. then the wheel is locked. Grab the steering wheel like you are driving angry. attempt with decent force to turn the wheel back and forth. You will get stopped in both directions. Do this 3-4 times, then stop with right turn pressure on the lock.Then, hold that pressure and slowly turn the ign key to run. It should unlock, and start.
Instead of starting the car, though, immediately take the neg batt terminal off. This will put you in a position to install a column lock bypass because the lock pin is retracted.
You can gat an optional unlocker, but sometimes the lock pins are worn and won’t retract properly. This is what causes the pull key wait 10 seconds because the bcm is timing from the moment you turn the key until the lock is fully retracted. If it takes too long, then the bcm thinks you are trying to steal the car.
All the bypass designs mimic this timing circuit so the bcm is happy, even though the column lock is actually disabled whet you add a clb kit
Old 07-08-2020, 04:21 PM
feeder82
feeder82's Avatar
Take the steering column apart remove the locking pin. Saw it off. Buy tuning software and change the 2mph cutoff to 200mph
Old 07-09-2020, 07:27 AM
oharal
oharal's Avatar
Just call Compliance Parts and talk to the guy I forget his name. He is absolutely TOP NOTCH and he will get you back up and running in no time flat. You WILL be satisfied!! My column lock stuck on at my apartment complex mail box center about 300 feet from my place and I called him and he told me it would be alright, pull a fuse (I forget which, he will tell you) and key the car on again saying that it will likely unlock *one time* before it really really gets stuck on. He was right so I creeped it back to my place and he had the part shipped to me lickety split and it worked flawlessly ever since. This is unique because it is the only fix that actually works forever.
Old 07-09-2020, 07:41 AM
v6turbo87
v6turbo87's Avatar
No doubt that will work, but buying an LMC5 and installing it is a lot less work a less expensive. ($50)
runner140* (07-09-2020)
Old 07-09-2020, 08:25 AM
feeder82
feeder82's Avatar
I know read his post the OP asked if there was a solution other than a bypass. I answered his question
Old 07-10-2020, 12:20 AM
Blue Blood
Blue Blood's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
but you may have to still deal with the 2mph limp mode if it’s not tuned out.
Old 07-10-2020, 10:07 AM
Dbl_D718
Dbl_D718's Avatar
The LMC5 takes care of the 2 mph cutoff by telling the BCM that the lock is working properly.
Blue Blood (07-10-2020)
Old 07-11-2020, 10:35 AM
3sACROWD
3sACROWD's Avatar
Column lock issues have been linked to battery quality /performance. How is your battery? IIRC the recommended Reserve Capacity is 120. To get a higher RC you may have to upsize your battery. I have a 78 series in my Z06 and have no issues with column lock. (292k miles on the clock)
Old 07-13-2020, 07:08 PM
Chad C
Cruising
Chad C's Avatar
Default What Battery?
What battery is suggested?
Old 07-13-2020, 08:07 PM
3sACROWD
3sACROWD's Avatar
If I were anywhere near my car, I'd look and tell the brand but I haven't seen my car since January. I can tell you that I bought it at AutoZone and it is an AGM battery so I don't have to worry about leakage.
Old 07-13-2020, 09:05 PM
Chad C
Cruising
Chad C's Avatar
This one maybe? Only AGM I see on Autozone? $300?
https://www.autozone.com/batteries-s...32142_232687_0
Old 07-14-2020, 02:50 PM
laurent_zo6
laurent_zo6's Avatar
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Richard is most helpful.
Old 07-14-2020, 09:08 PM
3sACROWD
3sACROWD's Avatar
I definitely did not pay $300 for a battery. I'm pretty sure it is a Durolast. IIRC the catalog calls for a 75 series battery. I had to go to the next size up 78. It fits. It will fill you battery tray but will still clamp down using the factory pieces.
Old 09-08-2023, 06:53 PM
daveycat
2nd Gear
daveycat's Avatar
Default Column lock forever part
what is the magic part you received ?
thanks, daveycat
To steering column locked
Quick Reply: steering column locked
