Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-20-2012, 10:51 PM   #1
Sinister-one
CF Senior Member
Default DTC Codes, need help with meanings.
These are the codes showing on my cluster display:
28-TCS
DTC C1233 RF Wheel Speed Circuit Open or Shorted - possible dead wheel sensor
DTC C1243 BPMV Pump Motor Stalled - ???
DTC C1277 Requested Torque Signal Circuit Malfunction - even bigger ?????
I'm pretty sure these were due to a dying or dead battery.
AO-LDCM
DTC B2282 Battery #1 Circuit
DTC B2284 Battery #2 Circuit
A1-RDCM
DTC B2283 Battery #1 Circuit
DTC B2285 Battery #2 Circuit
Sinister-one is offline   Reply With Quote
Old 03-21-2012, 12:34 AM   #2
8VETTE7
CF Senior Member
8VETTE7's Avatar
The LDCM and RDCM messages are likely battery related. Low battery or bad battery or loose or corroded battery connections.
The TCS codes could be the result of a bad EBCM or they could also be corroded connections or grounds.
Here's a thread with some info about C1243 worth reading.
For code C1233 I'd pull the wheel, separate the connector to the wheel speed sensor and look at the condition of the contacts. I'll bet that on a 2000 year C5 they are corroded or damaged. I'd also check the connectors on the other 3 wheels while I was at it.
For the C1277 code, have you cleared this code and does it return???? htere is plenty of reading if you do an extended search co C1277 in both title and text . Could be a battery issue, could be a ground at the EBCM, could be a ground at the PCM or could be a damaged wire at the EBCM or it could be a bad EBCM.
Given the commonality of grounds for the TCS codes you have, Id read the Bill Curlee thread about grounds and spend some time cleaning the many that are on the car:
http://forums.corvetteforum.com/c5-t...tion-long.html
8VETTE7 is offline   Reply With Quote
Old 03-21-2012, 07:04 AM   #3
LoneStarFRC
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
LoneStarFRC's Avatar
Location: Perseverance: The courage to ignore the obvious wisdom of turning back.
Good tips. Check your battery connections not only at the battery itself of course, but also at the pos. connection on the starter solenoid. There's been more than one guy that has found their's slightly loose.
If your making a battery decision soon, I can recommend the Sears Die-Hard Platinum P-4. It's an AGM unit made by the folks at Enersys in Missouri that mfr the Odyssey brand.
LoneStarFRC is offline   Reply With Quote
Old 03-21-2012, 08:37 AM   #4
Sinister-one
CF Senior Member
Well guys, I replaced the battery at the first of the year. It died one moring when I went out to turn the car on.
As for the other codes, I guess I'll be doing some reading.
Old 03-21-2012, 10:53 AM   #5
8VETTE7
CF Senior Member
8VETTE7's Avatar
Hmmmmmm. Not sure what happened to the first two links I thought I put in my post above but here they are. They relate to the C1243 code:
http://forums.corvetteforum.com/c5-t...surements.html
http://forums.corvetteforum.com/c5-t...c-c1243-h.html
Old 03-21-2012, 10:59 AM   #6
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
Let me toss in here to about the 1243 code. I had that happen to me as well. I followed the forum suggestions for manually powering the BPMV motor and it spun slow at first then picked up speed within a few tries. After putting things back together, I found that I still got the code about once out of every three times of starting up. I went back and did the manual power thing to the BPMV again yet it ran at full speed...so I measured the battery and it was at 12.6vdc static. Knowing that and its age of several years, I replaced the battery and now the 1243 code is gone.
I can't say that your issue is the battery but pairing the door control module codes that do indicate a low battery and the 1243 code, you might want to replace your battery, clear all codes, then see what comes back the next cold start.
dgrant3830 is offline   Reply With Quote
Reload this Page DTC Codes, need help with meanings.
Tags
2000, c5, ckt, code, codes, corvette, dic, dtc, malfuction, meanings, request, signal, torque
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
