Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-13-2012, 07:15 PM   #1
bighank
CF Senior Member
Default How do you remove a stuck 12 CD cartridge from the trunk CD player?
My factory 12 CD trunk mounted player hangs up occasionally. I usually just stop the car, turn the radio off. open the trunk and storage lid, slide the plastic cover on the player to the right and wait for the player to cycle and then pop up the magazine. Have done this several times.
Got "err" on the radio when switching from CD1 to CD2. Tried removing the 12 CD cassette as described above.
When you slide the plastic door to the right you get 3 sets of cycling noises not 12. Then NOTHING. Have tried this with the radio off and then tried it with the radio on.
When closing the door by sliding to the left get 3 sets of cycling noises and then NOTHING.
Now the radio does not say "err" it does NOTHING.
If I put a cassette in the radio it works fine.
Have another 12 CD player and would like to use it but would like to get the 12 CD cassette OUT OF THE ORIGINAL CD PLAYER.
How do I get the cassette with the 12 CDs OUT OF THE ORIGINAL PLAYER? Is there some hole you put a paper clip in like in a PC CD or DVD player? If not how do you get the loaded cassette out of the player?
bighank is offline   Reply With Quote
Old 03-13-2012, 09:41 PM   #2
AUandAG
CF Senior Member
AUandAG's Avatar
See my post on this thread:
http://forums.corvetteforum.com/c5-g...-magazine.html
AUandAG is offline   Reply With Quote
Old 03-14-2012, 10:15 AM   #3
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
I would imagine the only possible way is to remove it and disassemble it. I've had to do this on numerous cd players, computer optical drives and so on over many years. Never a simple and easy way. Had a single cd player in a BMW that had 4.5 discs jammed within. Yes, 4.5...I bought it used and discovered it didn't work and obvious why.
dgrant3830 is offline   Reply With Quote
Old 03-14-2012, 10:33 AM   #4
dougbfresh
CF Senior Member
Quote:
dougbfresh is offline   Reply With Quote
Old 03-14-2012, 08:05 PM   #5
bighank
CF Senior Member
Default If you aren't a midget getting the left bracket screws is a piece of work
Removed the 6 screws that attach the CD player to the brackets. Took out 6 smaller screws holding the 2 removable covers. Found the white plastic arm that when pushed slightly forward will eject the cartridge.
The real fun part was putting the left screws holding the bracket to the player back in. The bottom one is almost impossible to thread. Worked blind with a socket and finally got the screw started. Taking the left bracket off with the 2 nuts and bolts seemed even worse so I decided to go for the screws from the player to the bracket.
The guts of this beast looks like something made for the space shuttle.
Unless you know exactly what you are doing you could screw it up royally.
I'm good mechanically but this beast is a jig saw puzzle.
Will try it out this week and see if it hangs again.
Thanks for the assistance to all.
Old 03-15-2012, 09:17 AM   #6
dgrant3830
dgrant3830's Avatar
I hear ya...been there, done that, many times on lots of different types of players.
Reload this Page How do you remove a stuck 12 CD cartridge from the trunk CD player?
Tags
12, 2002, bolts, c5, c6, cartridge, cd, changer, corvette, magazing, remove, stuck
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
