Antiseize on Sparkplugs?
#41
You'll be hard pressed to find a spark plug nowadays that isn't nickel or zinc plated - the very same metallic materials used in anti-seize pastes to prevent galvanic corrosion. It's become redundant.
An uncoated steel fastener threaded into aluminum is a very different story. If in doubt, use anti-seize (lightly), but if you look at your new plugs and see the threads are a bright shiny silver color, no worries, they are plated and won't seize to aluminum.
#43
Won't hurt, and I'll be able to remove my plugs easily irregardless.
best
mqqn
