c5 oil pressure zero! HELP!
#41
vettegirl -
1st - hats off to you, not a lot of guys out there will tear into a car like you have - I salute you and toast you with a 1/2" ratchet drive!!
Yes, frustrating that some folks can put 250,000 miles and only change a battery, alternator & lightbulb or two.
Others aren't as lucky.......
All that being said, I have buddies of mine who own 911's, Mustangs, BMW's & Chargers and they all have had "issues".......the 2002 Porsche 911's issues are many, the BMW's are ELECTRICAL and are $$$$$$ to fix.
Keep us posted & hang in there,
CatCam
CatCam
#43
#44
Learned something about the filter.
Pick up a katech c5-r timing chain. While youre there if your block is already drilled for the timing chain damper you may also consider getting that from them as well.
#45
New balancer, pin it and if the timing chain is loose you can get an LS2 chain for very little money. They are beefier than stock.
#54
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless this is an engine that going to be hammered regularly on a road course or at the track,, the LS2 chain will be more than adequate. It’s a LOT better than the old LS1/6 chain. Sure there are much better chains but price may be a big factor in the selection choice!
Here the comparison between an LS2 chain (on the engine) and a used LS1/6 chain. Note the thicker links and if you look very closely, you can see the parting line in some of the rollers between each link. :
#55
Just went through the same situation with my car after i put the top end back on (oil pump was off for a few days). Anyways turned out that the valve was stuck in the LS6 pump so i had to tear it all back down and replace the pump, problem solved in my case anyways.......hope that helps to clear it up a bit.
