Trans Cooler Mount - Driver of Passenger
Old 02-13-2012, 05:16 PM
KingTut
Support Corvetteforum!
KingTut's Avatar
Default Trans Cooler Mount - Driver or Passenger side
I have my mounting straps to the A/C condensor made. I was just wondering if the side made any difference. Would think middle would not be "lined up with a fan" and not be as desirable.
The lines are shorter on the passenger side but it then shields the air from the radiator part of the trans cooler loop.
So I am looking for reasons why that is not the better of the two.
A second thought is does this extra hose, coil, etc make the trans pump have to work harder? Would there not be additional back pressure on the rubber hose going into the bottom of the radiator? I planned on replacing that section with braided line also but was currious what other thought of that idea.
Old 02-13-2012, 05:28 PM
AU N EGL
AU N EGL's Avatar
my trans cooler is on the passenger side.
the oil cooler is on the driver side
Braided lines under with high temp aircraft hose to insulate
Quick Reply: Trans Cooler Mount - Driver of Passenger
