Need help with this mess
A buddy and myself were installing longtubes on his car and everything went smoothly, but when we connected the battery after everything was complete, several things happened:
fans automatically came on, and never turned off, no key in ignition
screen flashed reduced engine power, also said service engine soon
and after all that it isn't starting, I am assuming its an electrical issue, just lost right now
then the DIC gave a slew of codes all which said no connection next to them
BO-RFA
10-PSM
28-TCS
40-BCM
58-SDM
60-IPC
80-RADIO
99-HVAC
A0-LDCM
A1-RDCM
I have no idea what to do and we need to get it running soon, any help is much appriciated
BO-RFA
10-PSM
28-TCS
40-BCM
58-SDM
60-IPC
80-RADIO
99-HVAC
A0-LDCM
A1-RDCM
done, but the pcm-10 no connections still shows up, and the fans still kick on when I remove the key, even though the car has been off for 12 hours
Fyi
FYI - The list you have only shows all the modules checked by the dic i.e . PCM - Power Control Module The codes will be 4 digits with a H (history) or C (current) at the end - i.e. P0401H
Might start here - http://www.c5help.com/c5_no_start.htm
unless you pulled sensors off or forgot to plug some back in, its gotta be the starter. take a breather, drink a beer, and double check anything made out of or containing plastic.
