Got an auto trans? Watch out for this gremlin...
CorvetteBrent (09-05-2018)
#62
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
That looks so much better than just changing the bulb...gotta do this. Thanks for putting the final touches on this gremlin.
#63
CF "Young" Senior Member
#67
Years in service, poor design???
Mine is a 2001 daily driver with just under 116K and it has no problem with that. My brothers '98 has 212K and obviously more years of service and has never had a problem with that part either. Possibly you have a problem unique to yours??? Never seen that before on a C5.
Now the oil pressure sensor is a different story........
#68
Same here. When I pulled hard
I saw all the ways to get a grip on it, but............
when I pull hard on the bulb, it looks like the socket it is in deforms. Is that possible? Could I break the socket and be SOL? Or can I pull on it as firmly as required to pull the bulb? Now i can take a simple
Quit laughing !! Every time I set out to fix something not broke, I break it !!!
Just FYI, the red piece looks just fine on mine, but then only 18K.
No need to disassemble console. Had the bulb exposed in a few minutes by using the suggested small screw driver and proceding carefully. Great input .
One thing I thought of was carefully hitting the bulb socket area with some lubricant or contact cleaner, but not sure what to use.
#69
I've been trying to figure out the same. It seems that most people who have done this ended needing to use a dremel or a small round file to widen the bulb space in the plastic light guide because the LED they used was too tall or wide. I would like to avoid that if possible. These are the dimensions of a 194 bulb:
I would say that this LED should fit without any problem, although I don't know if its light output/pattern would be OK:
It is available in white, blue, red, amber and green and it's $5.99 here (scroll down until you find it).
Or perhaps this one:
Also available in several colors and it's $5.99 too.
What do you guys think?
The Widest, 194 168 W5W 2825 Ever Made!
Outfitted with the latest Super Wide High-Flux low profile Leds
Designed especially for gauges, & applications requiring a super-wide large uniform field of bright light
Only 10mm diameter x 26mm overall
5Led Wedge Matrix Bulb
10mm dia. x 25mm overall
Outfitted with 4X 3mm Leds+One High Flux Forward Facing Led. Regulator protects from Over-Voltage. Rectified for ambipolarity.
Voltage: 12-18v
Beam Angle: 270 degrees
Polarity Bias: No
Voltage: 12-18v
Polarity Bias: No
#70
Great find....at that price it is worth attempting....if it doesn't fit it can be used for the license plate or under dash lighting.
#71
http://forums.corvetteforum.com/attachments/c5-tech/47691235d1329875038-c5-orange-shift-indicator-assembly-instructions-c5-shift-indicator-build-instructions..doc[/url]
Try this.. I built this a while back, still going strong!!!
CEL
CEL
#72
No problems as yet on my 2K but getting ready to replace radio and fix dual climate display problem. So wonder if I decide to put in LED light where to get it? Any help here appreciated much.
#75
OK so I checked post #69 and the question is; is the LED one OK and is getting the old bulb out of it's socket that difficult as I am reading and if so what's the magic trick for removing?
Thanks again all!
Thanks again all!
#77
See the little orange doo dad that points to the gear? I broke mine a few years ago while putting on a new shift boot. They aren't available, either.
I wasn't going to buy a $200+ shifter assembly to replace a 50 cent piece of plastic. So now, I have to look forward to my shifter erupting in flames now, huh. Oh well, it doesn't matter if there's a bulb in it since I can't see which gear it's in anyway....
#78
I tried that for a while and it drove me nuts....especially at night. I have a spare boot (got it on ebay) with the PRNDL intact for the future....who knows, it might break, even with the improved bulb.
#80
Ok, so I am upgrading my stock stereo to accept ipod via kit from Double D mods, so I am also changing my auto shift boot to 2 tone while I am in there and same for E brake boot and since my shifter bulb was toasted and read this thread and what I came up with and just ordered is a 194 LED with Globe, 11mm x 26mm, should fit and also has a 270 degree beam angle, which should be good to illuminate properly. Cool or warm white was my color choice.
It is the 12th bulb down on this page....
http://www.autolumination.com/194.htm
I will post back here on how well it works or doesn't work after I finish my project.
