Traction control warming up readinf
As post states. I picked my 99 Vette a convertible with 6 speed trans up from the shop that installed my BTR cam and new ls6 manifold. After I got it and drove a few feet the display showed traction control warming. I was told it wil go off from the shop after I drive for a bit but it never did. After driving for 15-20 minutes the light comes on the dash and it read service stability system. It has never given me these type of issues. Once I turn off the car, light is off and it’s fine. Drive a few ft and it does it all over again. Thank you in advance
2020 C5 of the Year Winner- Unmodified
Low battery is what everybody told me too. Clear the messages off your dash. Take the car out on a back road, slam on the brakes at about 60 a couple times. It frees up the IBCM piston. That worked for me. Haven't had the message since. Now I do that ocassionaly to exercise that system. Can't hurt to try it.
Received 19,305 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Wouldn’t the battery be charged enough to not cause issues if I had daily driven it for a few weeks without any low battery starting problems ? I have the battery out now for winter storage and it goes in the trickle charger in my shop every 3-4 weeks for the day.
With a voltmeter, with battery ground disconnected (or both cables disconnected) are you getting 12.7-12.9 volts?
Yes you could have enough charge to crank the engine over, but be weak enough to cause electric gremlins, even though it sounds weird.
Everytime I've had a glitch or gremlins on mine, battery is 12.4 or lower, trickle charge until normal voltage and the messages go away.
Low battery causes all sorts of warnings. But I was getting the same warnings when I started out with the wheels turned. Someone else mentioned that and it seemed to be true.
