OBD 1999 C5 no power can not detect scanner
Old 01-08-2012, 03:35 PM
helga203
helga203's Avatar
Default OBD 1999 C5 no power can not detect scanner
I've been useing hpt with no problems. Went out to the car to download some changes and the OBD is dead.Scanner can not detect power so i checked fuse box by foot rest and found a blown fuse 1# changed fuse and still no luck any advice. Got it it was 9# fuse
Old 01-08-2012, 03:37 PM
dougbfresh
dougbfresh's Avatar
does the cig lighter work
Old 01-08-2012, 03:38 PM
helga203
helga203's Avatar
got it; it was 9# fuse 10amp
Old 07-22-2012, 03:47 PM
boostedcatfish
boostedcatfish's Avatar
well ill just keep theis thread going instead of making a new one. im in the same boat but all my fuses are good, i checked the # 4 and #5 pin on the port and they both have ground. is there something im missing?
Old 07-22-2012, 04:11 PM
lucky131969
lucky131969's Avatar
Rule on threads is 45 days......
So you have a good ground on 4 & 5 , but what about 12 volts on pin 16? What codes do you have?
Fill out your sig !
To OBD 1999 C5 no power can not detect scanner
Quick Reply: OBD 1999 C5 no power can not detect scanner
