Need a GOOD alternative to Headlight insulators/tab stops/bumpers
#41
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Alright fellas, I'm fed up. Turned my lights on to leave work and everything worked fine. Got to the gym and after working out I went to flip the headlights up - nothing (on either side). Had to get out and turn both manual ***** a half turn. And of course, everything opened just fine. I'm at the point of wanting to sell this car due to this headlight issue (no I don't want the fixed headlight option). Here are my only 2 ideas left:
1. Try different gears, other than the hardened aluminum
2. Replace both headlight actuator motors. This would cost me about $460 but if it's a sure fix I'll gladly pay it at this point.
Heavily leaning toward #2, what are anyone's thoughts?
Examine the circuit and monitor CONNECTOR C1 on PIN A for the head light ON signal when you turn the head lights ON/Modules UP.
BC
#42
As BOTH lights are now being effected, that well could be a multifunction switch issue. To varify that is the problem you would have to monitor the raise voltage with a meter.
BC
BC
Thanks Bill! This could be the answer - unfortunately I have absolutely no experience with this kind of thing. The above diagram is pretty foreign to me. Is this a deal that you could walk me through to check, or am I going to have to take it in to the shop? I wish I knew more but am willing and able to learn...
#43
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Beg/borrow or Get a Digital VOLT OHM/AMP meter (one that you can actually use and read. We will be reviewing the schematic and getting voltage measurements on specific pins in the connectors.
NOTE (some meters require an engineering degree to use!)
Anyway, get a meter, and we can test some of the voltages. PM me when you ready to discuss this over the phone and do some probing.
PM SENT..
Bill
PM SENT..
Bill
#44
PM SENT..
Bill
PM SENT..
Bill
Thanks so much! I've got a couple friends with ohm/amp meters who I will borrow from. I will give you a call as soon as I have a little time to get under the hood...
p.s. - last night just the driver's side was getting stuck and not coming up. A few cycles of the headlight switch on/off and it eventually popped up and joined the passenger side in the up position. Any thoughts on that?
#45
Any updates on this???
I have been dealing with this exact problem but just on the passenger side. PIA to have to get out and spin the motor.
Let us know where you have found please!
#46
It's definitely a mechanical issue for me - I have found no evidence that it is an electrical/wiring issue.
I'm currently using braided PVC tubing over the 'down' stop bumpers to provide a little extra thickness to the stops and stop the motor/headlight a little sooner on the way down. This works great until the pounding eventually wears the tubing out and I have to stick another piece in there. I'm averaging about 2-3 months per piece. This was a suggestion by another forum member and it seems to be the best solution I've found, aside from replacing both headlight assemblies ($$$$).
#47
I have finally decided to try and make better reproduction bump stops. I hope to make reproductions made that are very close to the originals. I am making progress and hope to have them in stock by spring.
Rodney Dickman
www.rodneydickman.com
Rodney Dickman
#48
Headlight Insulators 97-04 C5
I too bought the insulators from Ekler's. They are brittle and break very easily. I have read where a guy made his own from the plastic on a paint brush. May take some time to do this but he said it works just fine.
#49
Rodney now has them for $2.75 and they are better than the original GM product:
http://rodneydickman.com/catalog/pro...roducts_id=309
#50
65elcmo
The only one I needed to replace was the one up front where the bar on the motor hits the insulator. The problem I had was when you turn your headlights off, the left front would go right back up. I didn't need to replace any other ones. If the other ones work fine, don't replace them. Hope this helps. I'm having a friend who owns a machine shop working to make one out of aluminum to see how it works.
#51
I replaced all my insulators with the ones from Rodney and my headlights are working perfectly. They are cheap enough to replace them all.
#52
I had the problem of my driver's side headlight not opening and after going through all the cheapo temporary fixes of reversing the bumpers or using some other hose/plastic thingamagig, I bought a bunch of Rodney's bumper stops a year and a half ago and have never again had another problem with the headlights.
This thread is 4 years old. Was there ever a resolution to it or did the original poster disappear?
I had a suggestion after reading through 3 pages- what is wrong with you? - Stop driving at night!
#55
Navigator
Sam Handwich (10-24-2023)
