Pass side window is having issues
Old 12-31-2011, 03:23 PM
Lifted07Sierra
Lifted07Sierra's Avatar
Default Pass side window is having issues
The window wont roll down using either set of buttons, but if I open the door to a certain point it works. And then as soon as the door is closed again it stops working.
Im guessing a loose connection somewhere where does the wiring go that goes into the car? obviously I know where its going in the door frame but which direction do you guys think it could be in?
Old 12-31-2011, 03:33 PM
1986coupe
1986coupe's Avatar
Take the rubber boot off and see what condition the wires are in.
Old 12-31-2011, 06:42 PM
Lifted07Sierra
That's my 1st step when I get back home. Hoping to see more replies so I can possibly figure out issue fast
Old 12-31-2011, 07:40 PM
lucky131969
lucky131969's Avatar
What you have found soo far, is half the battle. Now that you know the operation is affected by the angle the door is open, you know it's the wiring/connectors.
http://forums.corvetteforum.com/1578756354-post4.html
To Pass side window is having issues
Quick Reply: Pass side window is having issues
