Where do the brake pad clips go?
Old 11-08-2011, 01:01 PM
Bowtieguy54
4th Gear
Bowtieguy54's Avatar
Default Where do the brake pad clips go?
I am about to install a set of GM performace front brake calipers & pads. The pads came with a bag of hardware. I know where 4 of the clips go - each end of the abutment brackets but there are 2 other clips. I believe they are squeal clips but I can not tell where they go from the instructions provided. Can ayone provide a picture or explain in detail where this clip goes and what it does? Is it really necessary?
Old 11-08-2011, 02:36 PM
cdkcorvette7
cdkcorvette7's Avatar
If they are what I think they are they clip to the brake pads positioned such that the piston contacts the metal guard instead of the back of the actual pad. Do you have a picture?
Old 11-08-2011, 02:40 PM
gotz06?
gotz06?'s Avatar
I agree
Old 11-08-2011, 04:25 PM
CHJ In Virginia
CHJ In Virginia's Avatar
The third clip goes on the inside of the caliper. Look at it and you will see two small "arms" about 3/16" long pushed out from the rounded side of the clip. These locate the clip on the inside of the caliper. It will snap in place with a little pressure. This clip keeps the pads pushed all the way down and help alleviate squeel.
Old 11-09-2011, 12:28 PM
Bowtieguy54
4th Gear
Very nice explanation - thanks for the help!
Old 11-09-2011, 12:49 PM
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
just pop the other wheel off and look at it for guidance...
Old 01-10-2018, 09:48 PM
EC-C4
Cruising
EC-C4's Avatar
Hello I hope I haven't missed the boat on this thread. I am replacing the front pads and calipers on my 86 there are abutment clips that came with the hardware kit I am having the same issue as the original post here. I cannot for the life of me figure where these clips go. I pulled the other side off and both sides did not have these. If someone can please help I would appreciate it.
To Where do the brake pad clips go?
Quick Reply: Where do the brake pad clips go?
