VaraRam cold air duct question.
I've decided to go with the VaraRam system for my 03. Did my research and really only found 1 negative rating. My question is for the people that put this on, are ya happy with the performance? What my real question is about the VaraRam Power Duct they sell with it. Has anybody put this on at the same time and do you think its a plus to add it to the intake system. Thanks in advance.
VRB2 on my car for three years now. You are gonna love the real SOTP gains you will get. Take you time and be patient on the install. A buddy to help makes a difference. 3-4 hours.
I do not have the power duct so no help here from me.
You will probably experience some engine surging for the first 100-200 highway speed miles. This is normal as your car's computer is learning how to handle the extra air flow and related pressures.
I am sure someone else will chime in on the duct!
I have the VRB2 with Power Duct on my car (04 Coupe). Also have XSPower catted longtube headers and ECS mail order tune. Feels much stronger, but have no before and after dyno numbers to verify.
Am I happy with mine? Heck yes!
I installed it on my 98,but removed it after my computer fail to relearn the extra air input. I didn't want to spend $500 for a tune. After all the Vararam is only effective past 50 mph and then it's just a few H.P. Was not worth it for me. Rahter spend my money on other thing.
If you plan or already have other mods on your car that would complement this intake,then it may be worth it.
Mine put down 328/335 rwhp on a dynojet dyno with a vararam, power duct and an SLP axle back with no tune. Granted it was 67 degrees and the air was very dry. Either way I was happy with those results.
I never had any surging or anything like that. I actually took the car on a 500+ mile trip (each way) to Bowling Green KY right after installing it. That trip the car gave me 31mpg average including the "spirited" driving I did while down there.
It was a pain to install and a few choice words flew around my garage that afternoon. Would I do it again? Hell yes!
Dennis (c5bearsfan) @ doubledmods.com hooked me up with a good deal on the whole set up and I couldn't be happier.
I figured it was a good mod to do to get me through till I can do my heads/cam/intake/headers/tune next spring and would be a good supportive mod to those as well.
My $.02 for what its worth.
Good luck!
Edit; by the way mine is a 2000 6 speed if it makes a difference.
Good luck!
Vararam install and performance
I installed it on my '02 eight years ago very happy with performance you can really feel the power difference at any speed but on the drag strip it pulls like hell the faster you go. Works well in the rain so don't worry about hydro-lock unless you submerge the car above the front bumper but that's just common sense. I added the power duct but i did it at the same time I installed the unit. It would help if you had someone to help topside. Be patient takes 3-4 hours follow the instructions let the computor do its learn mode and you will be satisfied with the out come, Good Luck.
Iwent from stock to a Blackwing (bought really cheap) that had no effect on my ET's at all.I installed a Vararam and instantly dropped 3/10's at the strip.A year later I installed the power duct and dropped almost a 1/10 more,so 4/10's drop in ET is a very good bang for the buck!
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I run both. I went with the intake at first and installed the duct later. I noticed better throttle response with it. It also looks better with the duct IMO.
You won't find a better intake for the C5!
http://www.shop.jwmotoring.com/produ...&categoryId=27
Good luck!
Good luck!
Ehh...the car is drawing in colder air at the very least. I'd also imagine the Vararam has less resistance to flow overall than the stock setup.
I installed mine last spiring. 3hr job for me. Not too bad. You DO have to muscle on some pieces to make it fit. Great bang for the buck.Mine costed 240.00 shipped and there IS a SOTP difference!!! I do not have a power duct but heard from many that it does not help. Headers are next for me. My 2.73 gears need all the help they can get.
It gets you a whole 2 extra hp? You have to clean your filter twice as often.Remember you are now getting cold air and everything else rammed into your intake filter. What I'm saying is that using the varaRam by itself is basically useless. I know it make some feel like they have a track car right after they installed them. There are numerous thread on here,that would support what I'm saying. Now, if you replaced your TBI,Intake manifold,Install header,Xpipe,Some decent mufflers and maybe a cam you then got something,but just the varaRam by itself is not worth it. Just my option. I rather save my cash and install a better exhaust and just open a couple hole into the stock filter housing and drill a few holes into the fog light housing. I'll be making my own system for my 99 FRC play car using the stock filter box. Will cost me less and will preform better than the varaRam.
If you and I lined up at a good strip, all mods equal, except "holes" vs. VRB2, You are going down by five cars 3 outta 5 passes, allowing for driver error. The VRB2 comes into play at the big end. The dyno can't measure effects of forced cold air at 60-110 plus. No matter the filter you clean it when it is dirty. You throw yours away, I reinstall mine.
I know a C5 Vert, Coupe, (mine) and C5 Z06 that all cut 3/10ths or better with just this mod. Sorry, just a personally observed fact. Thunder Valley Raceway, Noble Oklahoma on the same night!
I think thats what he's saying. I went from a Blackwing to a Vararam and the difference is pretty dramatic for a bolt on part. Other than headers I can't think of another bolt on mod (sans a supercharger) that will give better TRACK results than a VR.
