Fast 90mm intake port gasket...what do you use now???
Old 11-04-2011, 08:34 AM
always faster
always faster's Avatar
Default Fast 90mm intake port gasket...what do you use now???
Well from the info that i got the FAST 90MM intake port gasket set is not available anymore...So what are you guys using ???
Does the ls6 oem one seal properly ???
Eric
Old 11-04-2011, 10:26 AM
chevy406
chevy406's Avatar
If you are talking about the 8 o-ring style gaskets on each runner that seal against the head, then just buy an intake gasket set from one of the auto parts stores or from GM. They will work fine. Make you have the button head bolts on your valley cover. I'm not sure what gasket to use for the 90mm throttle body. You can probably buy an LS2 TB gasket.
Old 11-04-2011, 12:17 PM
vettenuts
vettenuts's Avatar
Well that sucks. If you go OEM, go new and don't re-use. The FAST gaskets were a bit stiffer rubber than stock, if you have parts stores that have them in stock you could check to see if they are as soft as the stock ones.
Old 11-04-2011, 03:11 PM
printmanjackson
printmanjackson's Avatar
St. Jude Donor '06-'07-'08-'09
I got some FAST gaskets from Hinson a few weeks ago
Old 11-04-2011, 06:55 PM
always faster
For a 90mm intake ? I think that i ve read somewhere on the board that you got a 102mm.
Old 11-04-2011, 09:30 PM
chevy406
chevy406's Avatar
Be more specific - are you talking about the 8 port o-rings or the throttle body gasket? The LS1/6 cathedral head ports don't care if you have a 78mm, 90mm, 92mm, or 102mm throttle body opening.
Old 11-05-2011, 12:36 PM
always faster
Eric
Just read my first post i ask for intake port gasket set(wich are not o-ring) not throttle body o-ring.
Old 11-05-2011, 12:43 PM
always faster
They are in fact a lot softer than the FAST one
I tought that i could put a small bead or rtv in the groove of the each intake port and then put the seal in.This would make them a little bit thicker and less prone to compress...good or bad idea ???
Old 11-06-2011, 11:47 AM
vettenuts
vettenuts's Avatar
I wouldn't do that. See what Fel Pro and other have if you can find them to look at. Do you have the part #?
Found these on Thunder Racing's web site: Link
Found these on the "other" site: Link
Old 11-06-2011, 12:00 PM
always faster
Well it seems that i was misinformed and that the intake port gasket are the same for the 90-92-102 .So of course they are still available:
http://www.compperformancegroupstore...Category_Code=
http://compperformancegroupstores.co..._Code=146203-8
To Fast 90mm intake port gasket...what do you use now???
Quick Reply: Fast 90mm intake port gasket...what do you use now???
