12 disc changer error
Old 10-29-2011, 03:33 PM
davidwp97
davidwp97's Avatar
Default 12 disc changer error
I turned the ignition off in my 2001 Coupe off right after I switched from AM to Disc with my factory 12 disc changer. Next time I started it I got an 'err' message. I opened the sliding changer door and the discs turn and seem to be trying to cycle but the cartrige won't eject. I've checked the owner's manual and service manual but no help there.
Any suggestions?
Thanks,
David
Old 10-29-2011, 07:48 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
Sort of sounds like a disc is jammed. If it won't eject, then you'll need to pull it out and take the lid off to find out what's wrong.
Old 10-29-2011, 09:06 PM
DeltaBravo
Support Corvetteforum!
DeltaBravo's Avatar
I had similar problems, twice, and found a disc jammed up inside. I finally took the changer out and haven't missed it.
Old 10-30-2011, 09:23 AM
dgrant3830
dgrant3830's Avatar
I would imagine the usual cause for a disk to jam would be a homemade label coming off and sticking to anything and everything it can inside. Its possible a fuse blew that feeds power to it, wherever that might be.
To 12 disc changer error
Quick Reply: 12 disc changer error
