Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-04-2002, 01:10 AM   #1
flash1034
CF Member
flash1034's Avatar
Default How about a 160 or 180 degree thermostat to PUMP UP THE POWER?
The stock 2002 Z06 seems like its set up to run a little hot, probably for emissions reasons. Has anybody tried putting a 180 or 160 degree thermostat in a stock Z06 to see if it help the engine put out more power by giving the car a richer charge? Would there be any draw backs? It sure worked in my Jeep? Any thoughts?
Flash :seeya
flash1034 is offline   Reply With Quote
Old 05-04-2002, 01:33 AM   #2
MDL-01C5
CF Senior Member
MDL-01C5's Avatar
Default Re: How about a 160 or 180 degree thermostat to PUMP UP THE POWER? (flash1034)
Welcome to the Forum, Flash!!!:D
Putting in a lower T-stat is an excellent mod to make, and will free up some power that is lost to heat, but if SOTP (Seat Of The Pants) HP is what you seek, then this wouldn't be what you're looking for.
Whatever gains you get would be so small that you'd be very unlikely to feel any difference in the car.
Still a good overall mod, though, and one I recommend--just don't expect to feel anything off of it alone :cheers:
Get an intake like the Vortex or blackwing to start(if you've not already)--you WILL notice an improvement there :yesnod:
MDL-01C5 is offline   Reply With Quote
Old 05-04-2002, 01:36 AM   #3
Viprklr
CF Senior Member
Viprklr's Avatar
Send a message via AIM to Viprklr
You may see a slight difference in temperature with a lower T-stat, but you really won't see consistent results until you kick the fans on earlier. I have a fan controller/t-stat combo I got from Xtreme Motorsports and it keeps my coolant at 180 and my oil temps below 200 consistently, even in 100+ degree weather. If I go to the strip and go WOT often the oil will creep up a little more, but that is to be expected. :D Give Nate a call at Xtreme...he can help. Or, make your own fan controller for less than $20. :cheers:
Viprklr is offline   Reply With Quote
Old 05-04-2002, 02:46 AM   #4
no cure
CF Senior Member
no cure's Avatar
Default Re: How about a 160 or 180 degree thermostat to PUMP UP THE POWER? (MDL-01C5)
can you quote a source or show before/after dyno numbers or other data for this fact?
others (especially the GM racing folks) claim that putting in a lower tstat will allow the engine to run 'too cool' with deleterious effects re long term engine wear..
no cure is offline   Reply With Quote
Old 05-04-2002, 09:29 AM   #5
jschindler
CF Senior Member
jschindler's Avatar
Default Re: How about a 160 or 180 degree thermostat to PUMP UP THE POWER? (no cure)
This comes up on the forum every few months. I don't claim to know the answer, but food for thought. When I ran high performance boats (my last had Mercruiser 502 cu inch, 500 hp engines), they are all set to run at about 150 - 160 degrees. As you can see by the specs, these are highly tuned engines and have very good durability. The difference is they don't have to meet emissions or fuel economy standards. Even in very hard running they never went above 180 degrees, and I never had a bit of trouble with my engines.
jschindler is offline   Reply With Quote
Old 05-04-2002, 10:40 AM   #6
97 C5
CF Senior Member
97 C5's Avatar
I also thought about going with a lower ther. It helped the car run at lower temps in all my other cars so I figure it will help the vette. As far as performance?? I t just makes me feel better to see the gauge lower than 220 :chevy
97 C5 is offline   Reply With Quote
Old 05-04-2002, 11:18 AM   #7
6Speeder
CF Senior Member
6Speeder's Avatar
[QUOTE]Putting in a lower T-stat is an excellent mod to make, and will free up some power that is lost to heat
:yesnod: Going to a lower temp thermostat (with earlier fan turn on) doesn't free up power lost to heat, but it WILL allow your engine computer to get more agressive timing without detonation. This is what gets more power. I proved this on my engine with back-to-back runs both on the street using a G-Tech (showed 15 HP difference between running at 180 Vs. 205) and at the dragstrip where I ran 2mph faster and 2 tenths quicker starting at 180 Vs. 205. :cool:
6Speeder is offline   Reply With Quote
Old 05-04-2002, 12:15 PM   #8
borba
CF Senior Member
borba's Avatar
Default Re: How about a 160 or 180 degree thermostat to PUMP UP THE POWER? (6Speeder)
I put in a 160 tstat and a fan controller. I have the fans coming on at 175 and the car does not get above 180-185 in traffic. This setup works great and I know the engine appreciates it! :cheers:
borba is offline   Reply With Quote
Old 05-04-2002, 07:06 PM   #9
Evil-Twin
CF Senior Member
St. Jude Donor '03-'04
Evil-Twin's Avatar
you guys claiming running a cold engine given you HP gain without any cost.. obviously have not seen all the post about engin carbonization.. and engine knock due to build up.. you cant compare a boat engine to a car engine... if you run a bpoat engine a few hours a week you are lucky.. and their mantenmce schedule is way more intence than a car engine.. winton cup cars run at 210 F + - 5 degrees..for peak performance..I agree that lowerering summer temps are a good idea.. but too cold will cost so you have to be careful.. I have all three thermostates... the 160 is ok when its 95 + but at night if your driving its too cold.. the 178/180 thermostate is the all around best...sure you can play with your fan setings between daytime and night time but thatis a pain in the butt.. if you can keep the temps between 180 and 200 your doing good... below 180 can cause carbon bulid up.. and increased compression.. premature engine wear.. GM already has a proceedure for decarbonization.. at best ten degree will give will add .8 to 1.0 hp.. so for two hp is it worth it to risk engine damage..at the track you can set the car up for cold.. dense air is best... why hasnt anyone added an air conditioning coil to the air intake.... you want dense air.,.. years ago we use to use a cool can filled with ice ... becareful abouyt runing at night with cold temps... Ive seen my 160 thermostate give me 155 temp.. while driving to Atlantic City doing 75 mph at night with outside temps at 50 F.. so the 160 is not a good day time night time thermostate
Evil-Twin is offline   Reply With Quote
Old 05-04-2002, 09:42 PM   #10
jschindler
CF Senior Member
jschindler's Avatar
Default Re: How about a 160 or 180 degree thermostat to PUMP UP THE POWER? (Evil-Twin)
I've been reading this Forum for a year now and have not seen one single person post that a C5 has had "engine carbonization" problems. There are people who theorize about it, but none that have actually had it happen. Also, my Tahoe has been running at 160 for almost a year now, and I can report zero problems in about 11,000 miles of running with it.
And what about someone who only drives three miles to work. Their car will never get above 160 degrees. Are their engines falling apart on them? The only issue is if the oil does not warm up completely they have to change it more often due to condensation not burning out of the oil. Millions of people only drive very short distances and their car never warms above 160. I just don't believe it is harmful.
And for your comment about boats. I agree that they don't get driven as much. But if it's bad for an engine, any engine, why don't they runner hotter thermostats in them. The maintenance schedule on boats only effects things like oil changes. There is NO maintenance schedule for tearing them down or "de carboning" them ever.
Old 05-05-2002, 11:12 AM   #11
6Speeder
CF Senior Member
6Speeder's Avatar
Quote:
...at best ten degree will give will add .8 to 1.0 hp...
:confused: I am curious about your source for this data point. There is good scientific data to support cooler air giving more HP, but coolant temp? And how would you support that with testing, that's a pretty small number to try and measure, repeatedly.
The issue with coolant temp is trying to regulate the temperature of the cylinder head and combustion chamber. You want the head as hot as possible to keep as much heat of combustion to do work, push the piston, but not have hot spots which cause knock. Sure, Winston Cup motors run hotter, cubic money has been spent on those heads to optimize them. Stock LS1 heads, as cast, can't. If you run them a little cooler overall, you can eliminate hot spots, and the computer can all back spark timing, making more HP. :yesnod: :cheers:
Reload this Page How about a 160 or 180 degree thermostat to PUMP UP THE POWER?
Tags
160, 175, 180, deg, degree, degrees, degress, dyno, gain, good, jeep, ls, motors, power, run, stat, thermistat, thermostat, vs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
180 Thermostat question 99vettewsnc C5 Tech 48 09-29-2005 02:45 AM
How to make a 12 second LT1 6-spd car Nathan Plemons C4 Tech/Performance 29 07-29-2004 02:00 AM
Which thermostat is best for superchargerd cars? Jimmy O C5 Forced Induction/Nitrous 32 12-05-2003 11:56 PM
overheating - one last time mgriffis C1 & C2 Corvettes 41 09-19-2002 11:30 AM
Now They Want Me to Buy A Fan!!!!! Rant!!!! Viet Nam Vett C1 & C2 Corvettes 24 07-13-2002 01:09 AM
Thermostat results kkonen C4 Tech/Performance 35 06-21-2002 10:41 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
