Old 03-27-2015, 12:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Reset change oil light on C5
Old 05-03-2002, 06:43 PM
Bud Doggin
Bud Doggin's Avatar
Default Reset change oil light on C5
I forgot how... Help?
Old 05-03-2002, 07:26 PM
strypr
strypr's Avatar
Default Re: Reset change oil light on C5 (Wht98)
PRESS TRIP BUTTON ON DASH TILL DIC READS "OIL LIFE REMAINING --%"
THEN HOLD RESET BUTTON FOR A FEW SECONDS . :cheers:
Old 05-03-2002, 07:28 PM
ghost.rider
ghost.rider's Avatar
Turn the ignition on but don't start the car. :cool:
Bring up oil life % on the DIC. :D
Push reset, it should go to 100%. :smash:
Start it up and listen to the CORSA's purr :cheers:
Old 05-04-2002, 12:51 AM
Hex29A
Hex29A's Avatar
Here is a "cool" way to do it posted by CARPE DM
Put key in the "on" position and pump the gas pedal three times.
It was designed this way to help avoid another grease smear on the dash by the oil changer.
Old 11-17-2013, 12:44 PM
z71paul
z71paul's Avatar
I tried to reset my oil percentage as is stated above but mine doesn't go to 100%, after hitting the reset button as stated it shown ---% and then when I go back and start the car it goes back to it's original 42% oil life left. Any thoughts???
Old 11-17-2013, 01:13 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
You revived a thread from 2002 for this? Either hold the reset button till it resets or turn on the key and press and release the gas pedal three times. I'm assuming you have a C5, you didn't say, but did post in C5 so I'll make the leap. Your profile says 1990, so if it's a C4 there's a different procedure completely.
http://forums.corvetteforum.com/c4-g...t-working.html
Old 11-17-2013, 01:18 PM
ZeeOSix
ZeeOSix's Avatar
Here's the exact words from the Owner's Manual.
1. Turn the ignition to ON, with the engine off.
2. Press the TRIP button so the OIL LIFE percentage
is displayed.
3. Press RESET and hold for two seconds. OIL LIFE
REMAIN 100% will appear.
Are you holding the Reset button long enough?
To Reset change oil light on C5
Quick Reply: Reset change oil light on C5
