Engine Oil Level Sensor Wiring 1999 Coupe
Does anyone know where the wiring is for the engine oil level sensor (ie, which wire run/loom is in routed through)? It seems as though the wires on mine are severed.
On the same wiring run as the crank position sensor, there is a brown wire seemingly spliced to a black wire. Same colors as the wires on the EOL sensor...coincidence? (Why would someone loop the circuit like that?) It seems to me that these are the wires for the EOL sensor...am I correct?
FWIW, I have the FSM for my C5 & I have looked at the wiring schematics. But, the schematics don't really show any other wiring in the same bundle. Thus, my original question.
Thanks!
Thanks!
