12 disc cd changer won't eject the magazine: What's wrong with it?
Old 04-30-2002, 05:32 PM
UPS C5
UPS C5's Avatar
Default 12 disc cd changer won't eject the magazine: What's wrong with it?
I loaded some cds into the magazine, pushed it into the changer, closed the door....and it does nothing. Usually you can hear it load the cds into the changer. I tried to play a cd and nothing happens.
I proceeded to take the magazine out changer and it doesn't eject. What
could be the problem? Fuse? Cd not loaded correctly?
Any help much appreciated.
Thanks.
Old 04-30-2002, 06:47 PM
Scruffy
Scruffy's Avatar
Default Re: 12 disc cd changer won't eject the magazine: What's wrong with it? (UPS C5)
Sounds like you probably put it in backwards. Did you have to force it in? Try gently removing it manually. Pay attention to the arrow on the cassette.
Old 04-30-2002, 07:41 PM
UPS C5
UPS C5's Avatar
Default Re: 12 disc cd changer won't eject the magazine: What's wrong with it? (Scruffy)
Scruffy,
No, didn't have to force it in. It went in like normal, just won't come out. I tried
to manually force out with no luck. Thanks man.
Old 04-30-2002, 07:45 PM
SDVette
SDVette's Avatar
Received 1,295 Likes on 560 Posts
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Disks upside down perhaps? I think I fought that one once.
Old 04-30-2002, 08:06 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Default Re: 12 disc cd changer won't eject the magazine: What's wrong with it? (SDVette)
I had mine repaired three times for that PITA. They said it was a three hundred dollar repair if not under warranty. I had to send it with all the CD's in it. :eek:
Old 04-30-2002, 08:34 PM
UPS C5
UPS C5's Avatar
Default Re: 12 disc cd changer won't eject the magazine: What's wrong with it? (John Shiels)
Thanks for your comments guys. Instead of sending the changer in for repair
is possible to purchase an aftermarket cd changer that will work with the head
unit?
Old 04-30-2002, 10:19 PM
2k NMB in NC
2k NMB in NC's Avatar
Default Re: 12 disc cd changer won't eject the magazine: What's wrong with it? (TexasRedY2K)
I bet the reason the mag won't eject is that your changer door is broken. There is a SMALL plastic tab on the door that depresses a switch when the door (fully) opens. Break this tab and the mag will never come out.
You can take the face plate off the changer and you will see the tab as well as the switch. Glue a small piece of something in where the tab belongs ( or simply re-glue the tab back in place) and cover with a small piece of duct tape. I've repaired like this before and it holds up great. Much cheaper than a $250 front door repair.
Good luck.
-GR
Old 04-30-2002, 11:24 PM
UPS C5
UPS C5's Avatar
Default Re: 12 disc cd changer won't eject the magazine: What's wrong with it? (2k NMB in NC)
Hey guys, I'm happy now. It's fixed. I got a bit frustrated and took the cd
changer apart and by accident I hit a little white switch mechanism that released the magazine. I put the changer back together and everything
works great.
Thanks to everyone who posted.
Old 05-02-2002, 12:25 AM
Roofless
Roofless's Avatar
St. Jude Donor '11,'13
Disconnect the battery cable (negative) for a few minutes and try again.
Old 04-23-2014, 09:29 PM
Lewisvan
7th Gear
Lewisvan's Avatar
My 12 Disc is stuck as well. You all have said that the face panel pops off. It felt really tight I guess it just has some strong clips to over come. Any Suggestions on a certain spot to start?
To 12 disc cd changer won't eject the magazine: What's wrong with it?
Quick Reply: 12 disc cd changer won't eject the magazine: What's wrong with it?
