Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-22-2011, 06:41 PM   #1
1fitbody
Junior Member
Otis Lane
Default ABS and traction control light
My ABS and Traction Control light comes on sometimes and will not go out. Need help
1fitbody is offline   Reply With Quote
Old 08-22-2011, 07:13 PM   #2
dougbfresh
CF Senior Member
Pull codes from the DIC-Post codes!! Use Advanced search if you don't know how to get the codes from the car.
dougbfresh is offline   Reply With Quote
Old 08-22-2011, 07:17 PM   #3
m6 c5
CF Senior Member
m6 c5's Avatar
Pull your codes and post them including if their is a h or c following it and then clear them to see which ones come back, that will give you an idea of what to look for.
You can view your codes by holding down options and pressing the fuel button 4 times, you then can hit reset to view each code manually. I believe you can scroll thru the main categories with options and trip buttons and go within those categories to actually see the codes with fuel and trip, not too sure on that though.
m6 c5 is offline   Reply With Quote
Old 08-24-2011, 05:57 AM   #4
Trunkflapper
CF Senior Member
This is what happened to me for about 2 weeks before my PCM quit on me. Just be prepared for that, just in case. What year is the car?
Trunkflapper is offline   Reply With Quote
Old 08-24-2011, 07:46 AM   #5
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
As already requested, codes will tell you and us, what's going on. I was having the same issue but got a code for the BPMV turning slow or stalled. Turned out, my battery was a bit low as it doesn't get driven as often these days. Charged it up, no more code for the BPMV
dgrant3830 is offline   Reply With Quote
Old 08-26-2011, 09:36 PM   #6
1fitbody
Junior Member
Otis Lane
It's a 2000
Old 08-26-2011, 09:42 PM   #7
sami85L98
CF Senior Member
sami85L98's Avatar
Quote:
yep, check the battery first, AVR test and let us know. I had the same situation while driving to work, since iam a mechanic and as soon as i reach my shop did teh AVR test and there ya go my alternator was bad and i was driving on a reserved battery, so when battery drained some and i started getting that message.
Is DRL light relays making buzz sound as well in passenger foot well area? if so you know they dont get enough voltage since battery is not strong enough or alternator might not be charging battery anymore.
Remember Alternator wont go just like that, it goes kaboom over some time, as battery is too low and laternator had to keep up.
sami85L98 is offline   Reply With Quote
Old 08-27-2011, 09:48 AM   #8
TroyPyles
CF Senior Member
TroyPyles's Avatar
I had the dealer flush and fill the brake fluid on my 2000 and now I'm having intermittent ABS/Traction control warnings too. Any connection with the flush and fill?
TroyPyles is offline   Reply With Quote
Old 08-27-2011, 11:03 AM   #9
dgrant3830
dgrant3830's Avatar
Quote:
Possibly as the BPMV needs to be actuated. Simple and quick way is to find a puddle and spin the wheels enough to activate the AH.
Old 08-27-2011, 07:22 PM   #10
TroyPyles
CF Senior Member
TroyPyles's Avatar
I'll give it a try then. No puddles in St. George, UT this time of year though. I think I saw a puddle once but it evaporated in 13 seconds in the 7% humidity and 103 degree heat.
Old 08-27-2011, 08:29 PM   #11
dgrant3830
dgrant3830's Avatar
I know St. George very well myself. Just go around a corner and hit the gas nice and hard and the AH will activate. Just insure no one is near. I'm trying to think of a place there to suggest but at this time of the year, as you know, there really isn't anywhere. You could try the flats out in Hurricane. Dirt would do just fine too but don't want you to possibly mess up the car.
Old 08-27-2011, 11:01 PM   #12
toddk
CF Senior Member
toddk's Avatar
As several of the posters requested, pull your codes and list them here for us. (Hold Options, press Fuel 4 times) . The TCS module should report codes which will lead you to the root cause, then try a search here for that specific code. Without your specific failure codes, everyone is guessing at many possible outcomes.
If the TCS/ABS lights are on, I am pretty sure AH, ABS & TC will not work at all. I just went through a C1214 repair today (DIY thread) which is another common intermittent fault along with the slow motor issue which dgrant3830 experienced. Unfortunately it's not easily fixed in Y2K cars.
Todd
toddk is offline   Reply With Quote
Old 08-28-2011, 12:08 AM   #13
BigGun
CF Senior Member
BigGun's Avatar
Todd
Until you pull the codes it is just a guess.
BigGun is offline   Reply With Quote
Old 08-28-2011, 12:20 AM   #14
toddk
CF Senior Member
toddk's Avatar
Yup. My money is on C1214.... Come on, big daddy needs a new EBCM.
Todd
Old 08-28-2011, 07:25 PM   #15
m6 c5
CF Senior Member
m6 c5's Avatar
Todd
Correct none of the "nannies" work when the lights come on. I tested it out just to make sure.
Old 09-11-2011, 04:57 PM   #16
1fitbody
Junior Member
Otis Lane
Old 10-24-2011, 02:26 AM   #17
corvettemorris
Junior Member
corvettemorris's Avatar
I have a 2011 GS, mn6, f55 with about 6k miles, purchased new. Last night i ran over a jaring bump/depression in the road, and it seemed as if I felt the ABS engage (idon't remember braking). After the bump in the road, both the ABS and Traction Control light came on, and the DIC flashes "Service your Traction Control". Also, the traction control button on the console stopped working when the warning lights came on.
After shutting down the motor and restarting (several times) the ABS and Traction Control lights and the DIC "Service your Traction Control" warnings returned. The car seemes to perform as usual, but I have not tried to push the car to the limit to see if the ABS or traction control will still engage.
Is this a common problem with the C6? What causes the problem and what is the fix? I know this may require a trip to the dealer to fully resolve the prooblem.
corvettemorris is offline   Reply With Quote
Old 10-24-2011, 09:36 AM   #18
m6 c5
CF Senior Member
m6 c5's Avatar
Seeing that your car is still under warranty you should be able to take it in and have it fixed. But to understand what is wrong with the car you are going to need to pull the codes.
Also you would probably have better luck in the C6 forum.
Old 11-26-2011, 02:01 AM   #19
corvettemorris
Junior Member
Here is the follow up on the warning lights "ABS and Traction Control" on my 2011 GS.
When I picked the car up from the dealer, they report there was a code "C0035". The left front hub reads "0" when moving. They replaced the left front hub assembly, test drove and no codes returned.
The car seems to run perfectly well now.
Old 06-23-2012, 11:28 PM   #20
ymash
Junior Member
ymash's Avatar
Quote:
Originally Posted by 1fitbody View Post
It's a 2000
I had the same problem. I read in another forum to get a test light and poke the green wire on the top of the ABS pump (while the test light is connected to battery power). At which point the pump should come on. The test light will become hot after a few seconds, put the test light out. wait a one minute and do it again. do it four or five times until the test light sire doesn't become hot anymore.
One note; when I did this the first time, the pump didn't come ON. it was becasue I was using a high impedence test light, use teh cheap ones. Or, what I ended up doing is getting a wire and attaching a 30 amp fuse to it and ran it directly to the green able. I blew 3 fuses as I was doing it, until it stopped blowing fuses, now it works fine.
THe problem is a siezed pump because or very little usage. If you don't want this to happen again, drive harder, make the traction control some ON here and there. Same with ABS brakes.
Hope this helps!!
ymash is offline   Reply With Quote
Reload this Page ABS and traction control light
Tags
2000, 2007, abs, antilock, c5, control, corvette, ight, lamp, ligh, light, replace, straction, tracktion, traction
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
