LS1 oil consumption, did I get lucky?
Old 08-19-2011, 09:57 AM
mchicia1
mchicia1's Avatar
Default LS1 oil consumption, did I get lucky?
I keep reading about oil consumption issues for LS1s...
I picked up my '99 4 months ago and have done just the one oil change. It has over 3k miles on the oil and the dipstick literally has not moved in two track days and a hundred spirited runs on the street. Stock ls1 style pcv with no catch can.
Am I the exception?
Old 08-19-2011, 10:13 AM
lucky131969
lucky131969's Avatar
Am I the exception?
So the question for tech is: Why do I not have a problem?
Old 08-19-2011, 10:15 AM
mchicia1
mchicia1's Avatar
You can move it to general if you want, this is just out of curiosity really. I just want to see how many people really have this problem, because if it is a lot, I will be babying the hell out of this motor (may not even mod it as much).
Old 08-19-2011, 10:20 AM
lucky131969
The oil consumption issue has been discussed on this forum for 8 years(at least). If you search, you will find plenty of info, to include TSB's, those that had their cars repaired under GMPP, etc. I have no abnormal oil consumption on my 99 with a vortech. I do not track my car, or beat on it though.
Old 08-19-2011, 11:02 AM
Vettmann17
Vettmann17's Avatar
My 2002 with 77K on the clock has no noticable oil consumption and I ususlly go about 5K between changes. The car is completely stock and I don't beat on it. I drive it every chance I get and drive mostly highway. I am the original owner so I can tell you it's been driven that way since day 1. I've owned six Vettes so far and I can tell you from experience that the key to longevity is maintenance, maintenance, maintenance. Good luck with your Vette, you should get many, many miles out of it!
Old 08-19-2011, 12:39 PM
phil hunter
phil hunter's Avatar
My 2001, which I have owned since new, has never consumed oil. It isn't a daily driver and is not raced though. Enjoy the Vette.
Phil
Old 08-21-2011, 08:05 PM
dcandel
dcandel's Avatar
Oldtimer
Bought my 99 coupe last year, now has 67K on the clock. Change the oil every 3500 miles. Doesn't use a drop between changes.
Old 08-25-2011, 10:50 PM
DeFormula
DeFormula's Avatar
I've owned two LS1 cars and neither used any oil with 3,000 mile plus oil changes. Current car is supercharged with 63,000 miles.
Old 08-26-2011, 01:53 AM
cdkcorvette7
cdkcorvette7's Avatar
I lose about 1/2 - 3/4 of a quart between changes. 01 C5 Coupe with 100K miles and full bolt-ons. I do run the occasional HPDE. No drag racing...
I've only heard about this being a common problem on 01's. There was a TSB on it a long time ago.
To LS1 oil consumption, did I get lucky?
Quick Reply: LS1 oil consumption, did I get lucky?
