Coolant reservoir tiny leak. Repairable?
Old 04-01-2009, 11:01 AM
karlfs99
Cruising
karlfs99's Avatar
Default Coolant reservoir tiny leak. Repairable?
Howdy all. The coolant reservoir (passenger side in front on battery) seems to have a small leak. I notice a tiny bit of bubbling water leaking from about an inch stretch of seam after driving. The reservoir almost looks like it is two pieces bolted together. Is is possible to unbolt, change a seal or lay down some silicon or something, rebolt and be good to go? Or replace the whole reservoir for 100-200 bucks?
Thanks for any assistance!
Karl
2003 QS Z06
Old 04-01-2009, 11:12 AM
nextime
nextime's Avatar
I would say no that it could not be repaired.
Old 04-01-2009, 11:36 AM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Whatever you use to repair it, has to be able to withstand 18 psi and
temperatures that can reach nearly 250 degrees.
I wouldn't attempt to fix it.
Old 04-01-2009, 11:37 AM
karlfs99
Cruising
karlfs99's Avatar
Makes sense. I will purchase a new tank and replace this weekend. Thanks for the advice!!
Karl
Old 04-01-2009, 12:02 PM
nextime
nextime's Avatar
Very safe decision. I would hate to hear you repaired it and later on down the road it blew up.
Karl
Old 04-01-2009, 12:18 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
2 things
1. often the small hose will fail, allowing coolant to seep, a clean cut and reinstall fixes this
2. www.gmpartshouse.com contact Gene, new res for $60 or so
3. A new res. will make you get that "new car" feeling being able to see clear to the nice new Orange drink you swapped out of your 6 year old car
I did option 2, followed by option 1
live and learn
I think dad in FL had this problem on his 200k coupe also
Old 08-05-2011, 12:42 AM
Scoundrl
Scoundrl's Avatar
Originally Posted by SteveDotenMotorsports
2 things
live and learn
I did cut the hose end off first, then found the small crack in the reservoir. Replacing that tomorrow... I cannot see how a 'fix' of the plastic could hold up.
-Ken
Old 08-05-2011, 01:26 AM
PHILLY JOE
PHILLY JOE
Support Corvetteforum!
PHILLY JOE's Avatar
If it leaks on the seam . Be carfull a heat gun can work. After taking it out. Save some money. Hard to tell. Need the find the leak in the tank. Philly joe
Old 08-05-2011, 08:16 AM
leadfoot4
leadfoot4's Avatar
Received 1,339 Likes on 1,092 Posts
For $60, you're going to take a chance on a repaired tank? Secondly, the C-5 tanks have "baffles" in the bottom for some reason. In my case, it seems that they're there to collect "crud", and keep it from circulating through the cooling system.
After 10 years, my tank had collected quite a bit of crud, that solidified and wouldn't come out. For $60, I simply replaced the tank. And while I was at it, I replaced all the hoses too....
Old 08-05-2011, 03:24 PM
FourG63 97GST
FourG63 97GST's Avatar
I "repaired" my leaking reservoir about 5 times over a couple months, tried different epoxies, clamps, and a couple "maybe if I angle it this way" . I eventually gave up and bought one
feel free to try though
Old 08-05-2011, 03:57 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Soooo, everybody jumping in to help a guy in a 2 year old thread?
Old 08-05-2011, 08:04 PM
Got uid0
Got uid0's Avatar
St. Jude Donor '17
It helped me today. Glad it was raised from the dead.
To Coolant reservoir tiny leak. Repairable?
Quick Reply: Coolant reservoir tiny leak. Repairable?
