Oil Change Non-Synth vs. Synth
#62
Received 1,229 Likes
St. Jude Donor '11
News flash............yelovette gets ********* slapped to the ground and stomped on by CorvetteForum Icon
#64
Not funny. I feel like a dumb ***. Ehh still looks full at 6 qt. I do no its not danger low. But i do add more when its dirty. Then i can c the oil..thats funny
#65
I wasn't going to jump into this thread, but all of the reading I have done of used oil analysis data suggests the opposite, RP did not do as well as M1. There are a number of guys on bobistheoilguy.com who were very disappointed in the used oil analysis results with RP.
#67
#68
First of all your opinion of me exaggerating anything about this car that I invested 5 years of my 45 year automotive career is insulting.. you do cement work!!!! You remind me of that on board computer HAL in the Movie 2001 a space odyssey . As the ship was being destroyed, the computer HAL would keep saying every thing is A OK. I wasn't going to post in the thread again but your insult to my credibility caused me to address your post again.. I suggest you do whatever you want but your opinion means nothing.. at least not about automotive technology... When you are mixing your cement, I don't tell you to use the cheapest cement because the cement is only being used for a sidewalk, but then what about that trash truck that could back up on the sidewalk at the driveway to turn around.. OK this is getting silly... The C5 can operate in a 120F ambient environment, just sitting at a stop light in Arizona where black top temps can reach 160F... the C5 is a bottom feeder and when sucking 160F temps off that blacktop there is little heat exchange.. coolant can easily reach 240/260F and oil can easily see 300F.. and this is just going to the grocery store.... I don't know why I am trying to save you and your C5,, after all in your mind conventional oil is A OK. Let me get this straight, you said you beat your car so you use synthetic, but you are telling others that they can use conventional..you have no basis in fact , you have no automotive education yet you are offering advice as if it was gospel, to people based on your opinion. An opinion with no education.
The End
and with love
Bill aka ET
The End
and with love
Bill aka ET
#69
St. Jude Donor '11
btw lucky, you need to drain the last 1/2 quart before you refill with 7 quarts...
#71
http://www.mobiloil.com/USA-English/.../What_Is_Synth tic_Motor_Oil.aspx
Take a look , so an old man can learn.... it all starts in the ground
#73
PHILLY JOE
Use syn tech. Florida high temp area use 10 30 up noth use 5 30. Want to saVe money use walmart syn. Tech same specs. for corvetYs. Used it for yearS on my 03,s. Alot less. Neverer a problem. SOME PEOPLE THINK IS THE MOST IS THE BEST. I HAD OIL ANNL. FROM THE JET ENGINES AT THE AFB.. NO DIFF. PHILLY JOE
