Engine coolant airlock problem solution
I have just finished rreplaceing my water pump and some other stuff, the job went well. I was expecting problems getting the engine coolant filled due a airlock situation other members are having. My buddy came by with this tool, and it will work on any vehical, he said its a must have for foreign cars. It worked perfect on the vette. I saw one on amazon.com for $102, mine is on order. It might help some of you out also.
http://www.johnsonmfg.com/temp/J360CS.htm
It draws a vacuum on the cooling system and pull the coolant even into the heater core. I hope this helps sombody else I'm sold on it.
Steve
Steve
Per the Shop Manual, the way to purge air from a C5 is to rev engine to 3,000 rpms (and back to idle) until temp comes up to 200 F. Then fill and repeat several times.
You might want to read some of the over heating post lately and see if the shop manual procedure actually works.
I "know" this tool works I saw it. I'm just trying to pass along information that helped me, do with it what you will.
