Racing Fuel for Everyday driver??
Old 04-20-2002, 06:10 PM
LTD
LTD's Avatar
Default Racing Fuel for Everyday driver??
Are there any fuels other than 93/94 octane gasoline that can/should be added in order to enhance performance?
And is there any such thing as Horsepower in a bottle?
Thanks guys!
Old 04-20-2002, 06:17 PM
MDL-01C5
MDL-01C5's Avatar
Default Re: Racing Fuel for Everyday driver?? (LTD)
Thanks guys!
Nitrous :p:
Higher octane fuel won't do much, if anything, for you unless you're running higher compression, or are otherwise heavily modified.
It's not worth the money otherwise :cheers:
READ THIS!! http://forums.corvetteforum.com/zerothread?id=282975
[Modified by MDL-01C5, 5:19 PM 4/20/2002]
Old 04-20-2002, 06:38 PM
Crushinator
Crushinator's Avatar
Default Re: Racing Fuel for Everyday driver?? (MDL-01C5)
Yep, pretty much a waste of money. If my car were stock and a daily driver, I'd be very tempted to run 89 octane unless I knew I was going to do some spirited driving. Gas prices are way too high these days.
Old 04-20-2002, 07:31 PM
JerryL
JerryL's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Racing Fuel for Everyday driver?? (QuickSilver97)
With stock compression you will gain nothing using racing fuel.
Old 04-20-2002, 08:07 PM
Skeeter1
Skeeter1's Avatar
what about with my setup ? it is a semi daily driver, the compression is not high NA as it was built that way for n20 use of which I use about a bottle a week. recently I have been using 3 gallons of c16 racing gas, it seems to run stronger (placebo ?) but it is getting expensive @ >$7 a gallon, any thoughts.
Old 04-20-2002, 08:09 PM
Lashtal
Lashtal's Avatar
Well, if 93/94 Octane was avaliable out here in California then we would not have to use a booster of some sort.
Once in a while I go out and get the 100 Octane fuel. It does show more kick compared to our 91 Octane out here.
Is it worth the $$$ - not really. But I like to splurge a bit once in a while.
:cheers:
To Racing Fuel for Everyday driver??
Quick Reply: Racing Fuel for Everyday driver??
