What's the ideal shift points for the '97-'98 A4?
Re: What's the ideal shift points for the '97-'98 A4? (ntnsec5)
Nearly Stock, I would let it at about 5800.
When you have air-mods then I would raise a bit to 6000.
That worked best for me.
Over 6000 I didn´t gain anything.
Once you have more mods :) you will raise the shiftpoints more and more.
Michael
Michael
Re: What's the ideal shift points for the '97-'98 A4? (Austrian Vette)
Thanks for the tip. After my air mods, I did raise it to 6600...I just wanted to get the rev limit out of the way. I am also curious about shift points...1-2, 2-3, 3-4. What are the optimum shift points in MPH?
I programmed it with the hypertech and tried to get the shifts at the rpm`s
I wanted.
That was at 6000rpms at all shifts, when I had only Vortex.
I now will need to program for mph with the LS1 edit.
I will need to find out myself.
Want it shifting at 6200 for NOS
and 6500 NA on my heads/cam setup.
Michael
