Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-02-2011, 03:59 PM   #1
slipryvette
Junior Member
Default engine knock in 2008 LS3
Has anyone been succesful in getting a chevy dealer to repair a bad engine slap, or piston slap? This happens when cold start for a period, sounds like a cummins with a load knock. HELP
slipryvette is offline   Reply With Quote
Old 05-02-2011, 04:56 PM   #2
RSchleder
CF Senior Member
RSchleder's Avatar
Ahhhhh, maybe you'd do better in the C6 section of this forum
RSchleder is offline   Reply With Quote
Old 05-02-2011, 05:40 PM   #3
Z06X
CF Senior Member
Ehhh...C6/C5...what's the difference.
I can say one thing, my car slaps like hell and I hate it. I've had many built motors in my life and they didn't even slap like these LSx's do. Once I hit 165 degrees it purrs, but before that it's all clatter. Common problem...what can you do really? It's a well documented issue and really has no ill effects on an engine, you just would preferrably not whip the car cold. I putt around until I hit 155 or so, then start to get moving a little more. I can say though, it's really a quirk of these cars I could do without.
Z06X is offline   Reply With Quote
Old 05-02-2011, 05:48 PM   #4
AU N EGL
CF Senior Member
AU N EGL's Avatar
Normal.. Let it warm up for a min or two before you drive off
AU N EGL is offline   Reply With Quote
Old 05-02-2011, 06:08 PM   #5
slipryvette
Junior Member
Thanks; I know others share same noise, still runsssssssssss strong.
Old 05-02-2011, 06:22 PM   #6
ricknyc23
CF Senior Member
ricknyc23's Avatar
ricknyc23 is offline   Reply With Quote
Old 05-03-2011, 10:09 AM   #7
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Yes, some corvette customers have had success getting GM to replace the pistons...
check piston slap . com
99blancoss is offline   Reply With Quote
Old 12-12-2012, 11:14 AM   #8
don22u
Junior Member
My 2008 LS3. GM replaced the lifters. that didn't work.
GM replaced the camshaft assembly and lifters, removed excessive carbon from pistons, fuel injection bulletin- guess what, the knocking is still there.
A deep knock at start up, engine runs rough, lasts well over a minute; sounds similar to a diesel, so I gotta say, "that aint normal."
GM is looking at it again
My suggestion, Persist. By the way, anyone who says knocking is normal and doesn't degrade are incorrect. If the engines didn't require oil, then no problem, but the knocking is telling you tolerances are off and the banging between surfaces does degrade each, the law of physics and materials tells us that. So, on the immediacy maybe no problem over time come on
don22u is offline   Reply With Quote
Old 12-12-2012, 01:26 PM   #9
tlove32
CF Senior Member
tlove32's Avatar
Anyone have a video of the knocking sound of their engine?
tlove32 is offline   Reply With Quote
Old 12-12-2012, 01:44 PM   #10
C5Natie
CF Senior Member
C5Natie's Avatar
Quote:
Depends if youre still under warranty. If not it will cost a fortune for them to even diagnose it. A bottom end knock is not normal at all, especially if it sounds like a diesel. If your warranty expired them I would recommend to find a good shop familiar with LS motors to diagnose it. I would not go to a dealer after warranty. Usually that sound is associated with the rod bearings which are not the greatest oem.
C5Natie is offline   Reply With Quote
Old 12-12-2012, 01:46 PM   #11
C5Natie
CF Senior Member
C5Natie's Avatar
Quote:
Just youtube "ls1 knocking sound", tons of vids.
Old 12-12-2012, 02:55 PM   #12
don22u
Junior Member
I have audio. I placed a recorder on top of the engine, underneath the engine and in the cabin. Definitely can hear the clang clanging
As I mentioned previously, if under warranty, persist for the tech's will start it the next morning not hear it and say nothing's wrong. My audio's fixed that problem
Old 12-12-2012, 06:02 PM   #13
tlove32
CF Senior Member
tlove32's Avatar
Quote:
I'm aware of what it sounds like, my reason for asking was to determine if it knock is valvetrain related (slow knock) or if it's the bottom end (much faster knock)
Old 12-12-2012, 06:26 PM   #14
BRKLYN
CF Senior Member
BRKLYN's Avatar
@nelsonlopez19
Send a message via Yahoo to BRKLYN
Very common, my 01 z28 did the same thing. It's all good..
BRKLYN is offline   Reply With Quote
Old 12-12-2012, 08:07 PM   #15
don22u
Junior Member
Video won't do you any good. The valve train issue is a tear down of which you will not be able to determine anything by a video. You can change the lifter to ls7 but with the variable timing of the ls3 you're fooling around with kabooms.
I'd suggest you take it to a non dealership corvette shop. That's where the motor heads are that can determine your situation and get er fixed.
GM mechanics are bumper to bumper now. So today he works on a malibu, tomorrow your vette- hey they're all the same, they burn gasonline they say. Don't fool around with it if you don't know what you're doing for a crate is $13500 plus install
Good luck
Old 12-13-2012, 12:57 AM   #16
chassed
CF Senior Member
chassed's Avatar
These motors are crazy noisy. Especially if you have a cam swap.
With the C5 cabin literally right behind the engine, we are prone to hear it more than you would in an Fbody.
chassed is offline   Reply With Quote
Old 12-13-2012, 08:18 AM   #17
don22u
Junior Member
So what is your point that is helpful. I'm finding these forums are becoming places to.....
By the way, "these motors" are NOT "crazy noisy." They're smooth, fluid power engines through the range. Sounds like you have a diesel and weren't told about it
And as to the cam swap, the lift and rise, the lifters all have a synergy as well; yes they complement each other to deliver fuel and remove fuel remnants and burnt gases. So I don't understand how you can throw a comment out there that by replacing a component of a tested design, that it will be worse than the malfunctioning one that was replaced because it was bad
I'm a bit rankled in that I posted to seek help. What I've gotten is "crying in the beer", complaining and assumptions that do not pass the test of hey that might be a solution. That doesn't solve the comments and neither do yours.
I'd suggest if you're drinking heavily or smoking something you stop. Its messing with the ability to analyze, evaluate and solve
But thanks for responding.
Old 12-13-2012, 09:39 AM   #18
K-Spaz
CF Senior Member
K-Spaz's Avatar
The most expensive part of the fix is the gasket set. Go get a price on that, pull the motor, tear it down, pick up a set of pistons, get the thing bored and stick em in. Slap it back together and you're back in business. Gaskets should be about $550, Parts and labor should be next to nothing, pistons and bearings are cheap and so is machine work. Start with a piston that's round and cylindrical, stick it in a hole that's round and cylindrical, and the noise will be gone. There's no easier fix, and it ain't goin away without help.
K-Spaz is offline   Reply With Quote
Old 12-13-2012, 11:48 AM   #19
C5Natie
CF Senior Member
C5Natie's Avatar
Good luck
Im sorry but the LS3's in Corvettes do not have vvt nor cylinder deactivation. Only the L99 in the Camaro SS auto does and the 6.2L motors in trucks and suv's. My "LS3" block is a L92 that had cylinder deactivation, the 6.2L alu blocks are identical. The right valley cover with the oil passage blockages, a cam swap and LS7 lifters and no more vvt/dod. It runs like a clock, nothing went kaboom.
Old 12-13-2012, 01:59 PM   #20
robert miller
CF Senior Member
robert miller's Avatar
Quote:
Just trying to be funny here correct. NOT
robert miller is offline   Reply With Quote
Reload this Page engine knock in 2008 LS3
Tags
c6, chevy, clatter, corvette, engine, knock, knocking, ls3, nock, noise, piston, problem, slap, tick, warranty
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Piston Slap tj65 C5 Tech 16 08-04-2014 06:33 PM
L82, Forged piston "slap" Vet76te C3 Tech/Performance 34 07-14-2014 05:43 PM
How long do you hear piston slap on cold start? 06 C6 vert C6 Corvette General Discussion 44 12-14-2012 08:48 AM
'08 Engine knock at start up don22u C6 Tech/Performance 15 11-29-2012 08:40 PM
Does this sound like rod knock to you?? tlove32 C5 Forced Induction/Nitrous 10 09-05-2012 11:52 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
