Broke active handling wires during cam install. Where do they go?
Old 04-28-2011, 01:02 PM
SSmoked1
SSmoked1's Avatar
Default Broke active handling wires during cam install. Where do they go?
Moved the steering rack and didn't see the wires. They are broke about 8 inches off the rack. I can't track where they went into and I had no luck searching for a schematic. Any help is greatly appreciated!!
Old 04-28-2011, 05:33 PM
ICUALL
ICUALL's Avatar
Default Wire colors
What are the wire colors of the broken wires ?
Old 04-28-2011, 06:17 PM
SSmoked1
SSmoked1's Avatar
2 wires. One black and one red. They are coming directly off of the steering rack. I think it's called the direction control? Thank you for the schematic. I'll post a pic when I get home on the pc!
Old 04-28-2011, 07:34 PM
lucky131969
lucky131969's Avatar
It's called magnasteer......and if you tore the wires off the rack, you'll be replacing it. If you just tore off the connector...you may be able to repair.
Old 04-28-2011, 07:47 PM
lucky131969
No info in your sig.....can't post the correct schematic without.......
Old 04-28-2011, 08:19 PM
SSmoked1
SSmoked1's Avatar
Sorry Lucky! It's not my car but I should have added info in original post. Car is a 04 Z06.
Here are the wires I broke off the rack.
I ASSUME this is the connector the wires go into?
The magnasteer connector is in the same harness as the fan connectors correct? I just need to know which slot(A/B)the red and black wire go back into the connector.
Old 04-28-2011, 08:37 PM
lucky131969
Red to Gray
Black to White.
Old 04-28-2011, 08:49 PM
SSmoked1
SSmoked1's Avatar
Perfect. Thank you!!
To Broke active handling wires during cam install. Where do they go?
Quick Reply: Broke active handling wires during cam install. Where do they go?
