TCS No Comm .....
Old 04-19-2011, 03:31 PM
ChopperLoco
ChopperLoco's Avatar
Default TCS No Comm .....
... Tech 2 says the same.
All the other codes have the H - are they still relevant?
Its an 03 Z with about 22k miles
The battery was completely dead this spring(i didn't disconnect it thinking i may have to move it on occasion)
Now has a new battery.
Grounds look clean and dry...
Any thoughts?
Okay here are the other Codes;
10 PCM:P 1571 HC
28 TCS:No Comm
40 BCM:B 0503 H,B 0508 H,B 2588 H,B2592 H
58 SDM 1040 HC
A0-LDCM:B 2282 H,B 2284 H,U 1064 H
A1-RDCM:B 2283 H,B 2285 H,U 1064 H
A6-SCM:B 0851 H
B0-RFA 1255 H
Thanks once again for any help men!
Dom
NOT SURE WHY THE PUKING GUYS ARE THERE-I DIDN"T INSERT THEM!
Old 04-19-2011, 05:43 PM
lucky131969
lucky131969's Avatar
If you don't post them, how can that question be answered?
Old 04-19-2011, 09:40 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clear ALL the DTCs and see what comes back... Coud be left over DTCs from the battery reconnect. Post all the DTCs that come back after clearing.
BC
Old 04-20-2011, 12:52 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
I'd clear the codes and take it it for a ride and see what comes back and then go from there.
A dead battery causes all kinds of issues, that are typically cured by a new one.
Old 04-20-2011, 01:11 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
"H" means it is a HISTORY code or old code
Old 04-20-2011, 03:09 PM
ChopperLoco
LOL-I guess i was thinking if they were history it was not a problem.
Old 04-20-2011, 03:10 PM
ChopperLoco
BC
Will do-Thanks
Old 04-21-2011, 04:44 PM
ChopperLoco
TTT for help with the codes-First post!
Thanks Dom
Old 04-21-2011, 07:35 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
Thanks Dom
Did you do what the others said to do? Clear codes and drive the car? Are these the codes you have after doing that? If so they indicate you still have a voltage problem of some sort since you have door voltage codes showing.
You need to check your battery connections for corrosion tightness and also check the other end of the battery negative cable where it is attached to ground to make sure it is in good condition.
Bill
Old 04-21-2011, 07:37 PM
lucky131969
If there was not a problem.....there would not be any code at all.......
Old 04-21-2011, 08:23 PM
ChopperLoco
Bill
Thanks Bill
How does one clear the codes?
Will check negative etc.
Dom
Old 04-21-2011, 08:24 PM
lucky131969
Thanks Bill
Dom
http://www.c5forum.com/ayc/dtcdic.php
Old 04-23-2011, 05:39 PM
ChopperLoco
Thanks once again!
I miss-understood "clearing the codes",and have now done so.
Went for a drive-this is what i have:
10 PCM - P 1571 HC
TCS - No Comm
58SDM - U1040 HC
Any more thoughts?
Dom
Old 04-23-2011, 07:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks once again!
10 PCM - P 1571 HC
TCS - No Comm
58SDM - U1040 HC
Any more thoughts?
Dom
Check the fuses and grounds to the EBTCM first.. Report back
BC
Old 04-25-2011, 06:24 PM
ChopperLoco
BC
Which grounds should i be focusing on?
Old 04-25-2011, 06:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Chassis Ground G-101 and 104/108
101
104/108
Old 04-30-2011, 09:06 AM
ChopperLoco
[QUOTE=Bill Curlee;1577442047]Chassis Ground G-101 and 104/108
Thanks for the help again Bill-checked these grounds visually and with the test light-all good-not seeing any bad fuses either!
Dom
To TCS No Comm .....
Old 04-30-2011, 09:43 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you physically checked each EBTCM fuse with a METER and varfied that there is the correct voltage on each fuse??
Make sure that you read the fuses powered by RUN in ON & Start with the ignition ON and make sure that those fuses read full battery voltage!
BC
Old 05-04-2011, 08:52 PM
bob guzzy
bob guzzy's Avatar
I know this is an old post but it was very helpful my TC and ABS lights started coming on, but once and a while they didn't.
I did think it was the Traction control switch, but I was still checking things to make sure.
What I found was the ground next to the battery under the battery heat shield shown above by Bill Curlee in the second pic was super loose.
Thank you Mr Curlee you saved me quite a few hours of going crazy looking and testing.
Old 05-07-2011, 05:37 PM
ChopperLoco
Okay,voltage at the fuses is consistant with the battery-fuses are all good,checked all grounds and still no luck!
EBCM done?
Dom
Quick Reply: TCS No Comm .....
